>At the Cincy show (that's for Jen!) or the Ohio Symposium last weekend, Oneway introduced a sit-down lathe. It was very interesting and very tempting to me. When I have to do a production run of small items, I get tired of standing and with this lathe I could sit and get more work done.
Anyone see it? try it? like it? ordered it? They got 7 orders at the show.
>Ruth, The Apple Ridge Woodturners spnsored a fund raising (successful) to place one in the John C. Campbell Folk School. You might contact Gary Gardner (turningleaf@tds.net) to see if he's had personal experience with it.
>Ruth, it was introduced in Portland this summer and I sat down to try it and Kevin handed me a skew to knock the corners off a turning square! I said, "Who do you think I am, Alan Lacer?" Then he handed me a gouge and I did a little turning on it. At the time I was having some severe leg problems and thought seriously about buying one. I think you would need a long bench at the right height to get the most benefit from it........Ron
>Ruth, it was on display at the AAW bash in Portland. I sat down at it but didn't turn it on. It's based on their 12 inch model. Looks like a winner to me for people who need it. You might have a problem with a long spindle but it should work well for the small stuff.
>ruth, when I bought my Oneway 1640 I thought it probably would be the last lathe I would ever buy. Now I am not sure. I think it would be a great choice for those having trouble with standing for long periods of time.
>I tried it a few times and the office chair Kevin had would work just fine. You wouldn't use it for long spindles or hollowing anything large where you need more body movement. It would be great for small hollowing because you're not bending, you'd just be leaning.
>When I first saw it, I thought the same thing, it's for "old folk" or someone with a physical problem like bad knees, back, etc. I sat and turned on it a few times (when rotations are going on, the vendors play) and used a few different tools just to test reach and ease of use. I am so tempted to buy one. When I have an order for 3 or 4 dozen coffee scoops or ornaments, I get tired of standing in the same position, I take a break, walk outside, find a weed in the garden and it's 2 hrs. before I get back to the lathe. If I was standing up then sitting down, I'd probably stay at it until the job was done, maybe.
>I turned on this lathe 3 or 4 times using 3 different size tools.
It's super easy and smooth to rotate it up and down, almost could use one hand to do it.
Using a chair with wheels is good but what happens when you get a pile of chips and it won't move? But you don't have to move that much because, even in a chair, you still have the needed body movement for small items of any sort.
Would a tool with a long handle be cumbersome? Most of the tools I use for my production work are either unhandled or shorter handles so this is not a problem. I only use long handled tools on large items and would have the lathe upright for roughing and larger items. This feature is only available on the 12" and that means I'd have to keep The General; not that he'd ever leave my shop before he expired and I had to bury him. : )
You can have the lathe upright, when your feet or back get tired, put it down and sit for awhile, when you get tired of sitting, put the lathe back upright. This would keep me turning for longer periods on orders for a dozen or more small items; bottle stoppers, coffee scoops, ornaments, ring holders, etc. I wholesale these to 2 artisan shops and with this lathe I can keep doing this when I get old. (did I really say that?)
>I tried it also Ruth. Of course Kevin looked at me like I wouldn't need it for 30 or 40 years.I think it is something that folks your age might want to consider in the future.Maybe you could will it to me when you are done with it.....
>I checked it out too Ruth. It was strangely comfortable. I could see it being a real nice thing to have when I'm older and needing to sit on my butt more. I could see how it would be a wonderful thing for those who are wheelchair bound. What a neat idea.
For what you mentioned, yes, it would probably be far more than you need. I mini on a table that basically sits on your lap (heightwise) would probably work just fine, and much cheaper.
>Because having a mini low or lap height wouldn't be the same. The ways are still on the bottom so you'd be reaching over more. The Sit Down has the ways behind the work so you have clearance above, in front and below. And think about it, when would something behind a work piece get in the way of the tool handle like it does with the ways on the bottom? (did I say that in a way that makes sense?)
>Sitting down is NOT just for old people or people in wheelchairs or with physical problems. Yes, this lathe is designed with those people in mind and for their comfort however, not being old or have physical ailments, I would love to sit down to turn a production run. I would never think of using a sit down lathe if I was turning a few bowls or hollow forms or anything like normal turners. For anyone who has to do a dozen or more of an item because it's their "job" and they turn 6 to 8 hrs. a day, this "Sit Down" lathe is perfect for them.
Ok, you guys have convinced me not to get one until I'm old and feeble.
>Go ahead and get it if you want it. Then you will have it and be used to it when you DO get old and feeble - and then I can come up and turn on yours when I get old and feeble.
