Recommendations for exterior finial please?
Roger Dunn
Roger Dunn
>I'd like to turn a finial for the top of a post upon which a residential electiical service is mounted. One piece of wood will split due to the changing climate and exposure in Western Washington so I was wondering if laminations of teak or Western Red Cedar boards glued in a 'cross grain situation' with Epoxy or Resourcinol would fight off the elements? Any help will be greatly! appreaciated.
Thanks
Roger Dunn
Re: Recommendations for exterior finial please?
Mike Jones
>Along the US West Coast, Redwood is prefferred for exterior applications. I would not be nearly as concerned about the glue two-piece element of your project, as I would sealing considerations. If this finial is turned from either redwood or cedar, and the finished appearance desired is "natural wood", I would reccommend a product like Duckback, a semi-transparent sealer/finish. Oils will turn it dark, or black, especially the end grain.
If you glue up, avoid any end-grain pointing to the sky. Look at the tops of wood fence posts in your area and you'll see why.
If you plan to paint the finished product, there is a world of products that should give satisfactory results.
Hope this helps!
Roger Dunn
Thanks Mike
Roger Dunn
I would use white oak
Dave Smith, Longview, WA
>Hi Roger,
White oak has been used for boat transoms and other water related uses. It also has been used for whiskey and wine barrels for a long time. How big is the finial? I have several large pieces of white oak that might work for your project. I owe you, so the price is right.
Dave Smith
Building a white oak table in Longview, WA.
Roger Dunn
Re: I would use white oak
Roger Dunn
>Thanks Dave! I have some White Oak boards and so will probably make the finial in a laminated fashion with the flat grain up as Mike pointed out. The post is a 6 X 6 so the base diameter will be around 8" and the height around 8" too. Kinda' a Jabba the Hut looking finial.
Are you going to paint it?
Ron in Drums PA
>If so the wood is really not as important as the paint that is used.
If the finial is not going to be painted then Teak or Azobe are the best woods for unfinished woods that will be used outdoors.
Azobe is used for railroad ties (with no creosote) and lasts, in use, for many decades unfinished. It is a deep orange/red color and is very hard.
Roger Dunn
No, I'll just let it weather naturally.
Roger Dunn
