Calling Doug Thompson
Don in Central Illinois
>I am ready to order a couple of your gouges but have a question. I am planning on using these in my Kelton handle. I have the #3 handle and I believe it is 1/2". What are the measurements of the haft's? Do I need to get an adaptor? Plan on using the Kelton until I can have time to make a permanat handle. TIA
Re: Calling Doug Thompson
Doug Thompson near Cleveland
>Don, the shank is sized by the diameter of the steel. Example a 1/2 tool will have a 1/2 shank. This steel is sold .015 oversize so I turn the first 2 inches down to a common fractional size so it will fit all aftermarket handles or a common drill bit can be used to bore a wood handle.
The 5/8 and larger gouges have the first 2-1/2 inches turned down, also the 3/4, 1 and 1-1/4 tools all have a 3/4 inch shank.
At the symposium this past weekend some eyes were opened when I pulled out a 1-1/4 spindle roughing gouge with a 3/4 inch shank. Two guys from Canada bought them to rough out bowls... BTW - they grind the wings back like a bowl gouge.
don central illinois
>And the 3/8" spindle gouges will have 3/8" shanks, right? I'm going to have to get an adapter to go from 1/2" to 3/8" for my Kelton handle. Thanks a lot, I noticed that your 3/8" are out of stock, when will we see more? TIA.
>Yes the 3/8 tool will have a 3/8 shank. I did run out of some 3/8 diameter flute shapes. Crucible manufactures this steel only a few times a year, a couple months ago they ran out of full lenght pieces. So it was decided to buy everything they had three feet and longer just to keep going, it was very costly to say the least. Last monday I did receive a delivery of 3/8 stock and will start milling again a few days. The plan is to have another batch done in 6 weeks and hope to done in 4 weeks. Only two custom tools in this batch, one for a stone turner that's very interesting and another for a violin restorer, two totally different worlds.
This almost like a second job and my real job is seven days a week. I like to stay busy so this is perfect and metalworking is enjoyable to do, almost like woodworking.
........Near Clevelaand.....!!!!!
Michael Stadulis, in Gloucester County, NJ
>Hi Doug,
Being an Ohio guy...your signoff should something that puts ahex or whammy of some sort oon the BoSox. Then again, maybe you aren't an Ohio native and cheer another game besides the Indians.
Mike.....whose Phillies got swept out of the NLDS by those Rockies.
