REAL MILK PAINT
Another question about dyeing wood
keith zimmerman, Normal, IL
>Can water-based lacquer be used to seal wood after dyeing? I know that solvent-based like Deft can be used, but I was wondering if water-based would work as well.
keithz
Re: Another question about dyeing wood
Sure!
Mike Schwing from Md.
>This piece was done just that way. Airbrushed the dye, then sealed it with shellac, then sprayed water based lacquer. Be sure to let the lacquer dry for several weeks before rubbing it out. I had a hard time ridding the piece of sanding scratches in the lacquer, set it aside for a long while, then went at it again. After it had set for about a month, it rubbed out and buffed up beautifully.
Re: Sure!
Cyril Griesbach
>Mike, I remember this piece from several years back. I's just a beautiful now as them. Thanks for showing it again.
Maybe...
Brian Hahn in SW Wisconsin
>It really depends on what type of dye you are using. I use water-soluble dyes. Most, but not all, of the water-soluble dyes chemically bond to the wood so they are unaffected by water... unless you have an excess of dye.
Spraying on a finish is safer than brushing it on. Sealing with a thin coat of de-waxed shellac is the safest route for water-soluble dyes. Of course, that's not a good idea for alcohol based dyes.
I would try it on a scrap of wood first. Then you will know for sure.
