drying units/refrigerator
Mark Paulley
>Hello all,
I am inetrested in turning an old refregerator into drying box. I thought I read here or somewhere, someone recently gave instructions for building it right and the little extras that make the project work. Like a 20 watt bulb not a 60 watt. Can anyone please advise on the making of one of these kilns or dryers?
Thanks for your help!!! And thanks to Wood Central for being here
Mark
Re: drying units/refrigerator
Don in Central Illinois
>Check in the turning archives under kiln. I think it was Wally Dickerman that mentioned the 20 watt bulb. If I get a chance, I'll look for it also.
Bart Rhoads
>Just another idea but try to find an upright freezer instead of a refrigerator. With a freezer you can utilize all the space instead of just the refrig part. I have two that I use all the time but I use two 60 watt light bulbs and a fan.
Lan Brady
>The latest AAW magazine has a good article on using small refrigerators, and the 20 watt bulb.
Lan
Dennis Yoder
>Check out Cindy Drozda's website, she uses refrigs Dennis Y
Nelson
>Why use only the refrigerator side only? Why not the frezzer side also.
Allen Neighbors
>I use two refrigerators. One is Side-by-Side. Each side has ten 1/2" holes in the bottom and the top. Each side has a 20w bulb and a circulation fan on separate switches. I can turn on light or fan or both. In this one I dry rough-turned pieces and small blanks. Fan on one week/Bulb on one week/Both on one week. All of the on-time is around 4-6 hours if I'm in the shop. (I think that's correct, I'd have to look on the chart in the shop... I haven't been using the schedule for several months because I've been doing other things besides bowls.)
The other reefer is the old style with freezer on top. It has 1/2" holes in the bottom, the top, and in the divider between the upper and lower compartments. It has a 20w bulb in the lower part, and no fan. I store larger sealed blanks and some smaller chunks in this one, just to slow the drying time. Air circulates in through the holes at the bottom, and out at the top. If I put in some pretty wet wood, I will open the door for a few minutes everyday. I don't have a system for using the bulb in this unit like I do in the other one. I haven't had any wood to spalt in this one, but I have had some apricot crack like it was hit by lightning. Most of the time it works well enough to keep the cracking to a minimum.
For a Refrigerator Kiln to work miracles in drying wood, you'd have to be a lot more consistant with tests and records than I. I'm an active volunteer firefighter, and also have other projects that might let me be in the shop for 10 hours or might keep me out of it for days. I hope this gives you some food for thought.
Mark Paulley
>To all,
Many thanks regarding information on the refrigerator as a dryer.
Mark
