$30 Swing Away tailstock for PM3520 *LINK*
Jerry Hall
>I keep bumping up the tylenol, so it was time to ease up on lifting the 3520 tailstock.
Without a lot of forethought, just looking at every idea I could find, I cobbled together a solution with a $10 gate hinge. It works! Some refinements are pending, but they are optional. Let me know what you think. Below is a link to a slide show on putting it together.
Gate hinge swing away Tailstock
Re: $30 Swing Away tailstock for PM3520 *LINK*
>Clever idea. Are you using an outboard tool rest?
Robert D. Macgregor
>That's a clever solution to hefting the tailstock. I suggest you go ahead with alignment and locking plans, though. I use hinges just like those for a 2X6 divider gate in a horse barn and they develop substantial slop over time; I think after a while your alignment will suffer as a result.
Also, are you sure it is hefting the tailstock and not wet logs that makes you ache? You could switch to, say, pens and see if it hurts less (just kidding).
>Fabulous Jerry.` I'll take time to read it all later today.
Norm Smith
>Jerry, I built one yesterday which was posted on the WOW site by Ray Lanham. It works great also. However he uses ball bearing hinges which are expensive ($25.00 at Home Depot) but eliminate any slop.
You guys come up with some great solutions.
Thanks,
Norm
Steven Antonucci
What does the tailstock weigh?
steve antonucci
>Seems to me that the weight of that tailstock is probably a good training exercise for putting those big blanks up on the lathe? Rather than swinging away, has anyone ever made a little rolling cart? In a pinch, I bet it could be used (carefully) to make longer turnings by spacing it with some kind of rigid box (bolted to the ways, and then to the rolling cart...)
There you go, another project.
Steve
57lbs and it's awkward.
eliot d
>Nice idea , but it won't work for me because it would be in the way when using some of my hollowing rigs.
Steven Antonucci
But you've got a 20" swing!
steve antonucci
>Surely, you've put more weight over the ways than 57#, right?
I love my Nova and it's tiny little tailstock (one handed to the top of my tablesaw...)
Steve
Re: But you've got a 20" swing!
Norm Smith
>Steve, You should get a mans machine. grin, Grin
Steven Antonucci
It's not the size of the lathe that matters
steve antonucci
>but what comes off of it :-)
Sometimes, I think turners "compensate" for "other deficiencies" by buying bigger lathes. Any of the women turners here own a "big" lathe? I didn't thinks so... ;-)
Steve
Re: It's not the size of the lathe that matters
>Steve Actually I have 3 women friends with Powermatic 3520's and they both complained about the tailstock. I built a lift out of a barn door and pulley for one of them.
The problem with the big tailstocks is they are kind of awkward and if you set them down wrong you can hurt your back.
The turners I know that turn big stuff use all sorts of pulleys, lifts etc to get the wood on the lathe. At the Indy Fest The had a really cool electronic winch hooked up to a moveable A frame so they could lift the wood and roll it right over the lathe.
I'm strong and kinda dumb so I just lift the wood but I got concerned because I know most turners are older than I am and I aksed about how they get those big pieces on the lathe. Many had some sort of ramp, hoist, lift, or pulley system.
Dennis Yoder
>Steve, I have made a rollaway cart for my tailstock, works great. Jerry watch out for all those tylenol. 1800mg max perday or risk of liver damage. So my Drs say. Dennis Y
Steve Kubien
Steve Kubien
>I'm with you on the Nova tailstock. I tend to rest mine on the floor when not in use because it is so light.
Cheers,
Steve Kubien
Steven Antonucci
I once put 110# of wet white oak on my Nova
steve antonucci
>and someone here asked me- "How'd you get it on the lathe?" and I answered "I just picked it up and put it on."
I was being somewhat tongue in cheek when I made the comment. I think a lot of people with "big iron" tend to not make "big things", and I just find it funny that the tailstock weighs much less than what I'd consider a "big piece of wood". To me, it's a big piece of wood when I need to hold it with 2 hands and my wife or son to spin the handwheel :-)
Steve
Steven Antonucci
but have you every used it to turn longer than
steve antonucci
>the lathe allows? I've seen people back two lathes end to end and all kinds of other oddities. I wondered if the idea was as practical as is seems in my head...
Steve
really big wood
>Steve one of these days we'll be using wood so big it will be easier to pick up the lathe and spin it. :)
Final tuning of the Swing Away tailstock *LINK*
Jerry Hall
>I am going to call it good, and done. Slide show now shows indexing and locking to the lathe (pinned with a 5/16 carriage bolt.)
I think this fixture will hold up just fine. In any case it is a good prototype. Maybe I will be able to handle a few more big green logs now that I don't have to mess with the tail stock. I don't use an auxiliary tool rest, and have kept my bowls within the 20" swing of the 3520. If I do I will get the Vicmarc and hopefully figure out a way for it to live with my swing away fixture.
Thanks for your comments.
Gate hinge Swing Away Tailstock
Karen F
>Steve, I have three lathes now. My favorite one is a VicMarc longbed 3HP with a 24" swing. I bought the longbed so I don't have to move the tailstock off of the lathe very often. The mini Jet is portable and the Woodfast 20" swing is up at our cabin in the mountains.
I have a very accomidating husband. He just goes out and buys himself a new bow for hunting when I need new tools.
Gate Hinge Bends
Jerry Hall
>I left the tail stock on over the last few nights, and the hinge is slowly bending out. Too wimpy! This was pointed out above as a potential problem. So don't build one just yet!
I have posted the following on the slide show. THIS IS A WORK IN PROGRESS. IT IS A PROTOTYPE. THE HINGE FLEXES AND BENDS. A SOLUTION IS BEING WORKED ON. PROBABLY A 1/4" STEEL BACKING PLATE.
Stay tuned. Ray Lanham of WOW has an elegant but somewhat different design. Search the WOW File Cabinet for "3520."
Thanks again for your comments. Sorry to drag this out, but wanted your thoughts as I was going along.
Added a backer, and it is a done deal *LINK*
Jerry Hall
>It is now a sturdy solution, and I am happy with it. It will do the job for me. The slide show has been updated with the construction details.
Swing Away Tail Stock
