A question about dying
keith zimmerman, Normal IL
>I'm experimenting with leather dye. How long should I wait after the dye is dry before lacquering?
keithz
keithz
Re: A question about dying
Carole Valentine
>Phew! I didn't know what to expect when I read your subject "Question about dying". I thought OMG, is Keith ill? LOL
Can't help with the leather dye question.
>Keith I usually wait overnight. It drys fairly quickly and you could probably cover it soon. Be aware that many leather dyes are alcohol based so if you put shellac over it you can make it run. Spray finishes work the best. many rub on finished will sometimes smear it.
Fog Tanner
>I use water based dyes here in Texas, primarily due to the heat. The water based gives more working time in this weather. If I am doing a lot of pieces, I let them dry overnight as that is typically the last thing I do before shutting down. If I am in a hurry, I use a hair dryer and its dry in 5-10 minutes. I have given sessions at our club retreat several times in the past. The exercise was to turn a 6"-7" bowl, and dye it inside and out. The inside was dyed and limed. This was all done in an hour and a half using the hair dryer.
I have used the leather dyes before when helping a friend and he didn't have the water based that we needed. They worked with no problem and we used a heat gun on that piece. I typically seal the dye with a coat of shellac based sanding sealer. It will lift a little of the dye if use use too much. I typically use Liberon Finishing Oil as the final finish and haven't had any problems.
Another dye that works very well are the fabric dyes from Darhma (sp?). They are water based and have a large number of colors. I just did an ash bowl in hot pink, which I also limed. Since I have a lifetime supply of various colors from my wife and daughter's Tie Dyed shirt business, I will be switching over to those as the aniline dyes run out.
Sorry about that Carole
keith zimmerman, Normal, IL
>I realized I spelled dying wrong after sending it. Obviously, I meant dyeing.
Coincidentally, I saw my doctor yesterday and got a clean bill of health. Hooray for me.
keithz
