>I'm working on a project which requires a lot of spindles with "bulbs". I've found the bedan to be a useful tool to cut the beads and convex curves as well as size the straight parts of the spindles. I don't find it very useful to cut a concave curve though. I've been using a gouge for that portion of the spindle. I am sort of curious as to if anyone can share some tips about using a bedan to cut a cove or if it is even possible.
>I'm not as good with the bedan since I don't use it as often but I frequently turn coves with the skew. Starting the cove is always the hard part. The steeper the beginning shoulder the more difficult it becomes. It's also very difficult to cut a cove with a steep shoulder. For that I use the spindle gouge. Large coves like you show on that spindle are pretty easy to do with the Bedan or the skew.
I also have a technique I use to deep narrow coves with the skew that I can't cut with any other tool. I'm talking coves that are 1/4 to 3/8 wide and deeper than they are wide. I'm without a camera right now so I can't show you but when my new one comes in I'll try to remember to shoot some shots.
>Anything is possible, but why make it hard on yourself? The Bedan is made primarily for turning beads and parting. Stick to a spindle gouge. And BTW a sharp spindle roughing gouge is great for those long smooth gentle curves.
>I don't have a bedan, but have used a 1/4" bench chisel which is basically a thinner version of a single bevel bedan. Rather than
use varying parts of the edge of a spindle gouge, I use the lower part of the "sweet
spot" and pivot off the back bevel in an arc.
Like with the skew, I start the cut with the
sharp corner and once the cut starts it's controlled off the bevel rubbing.
If you stay in the sweet area you can pivot
down into the cove AND back up the other
side, normally a No No, especially with a
spindle gouge - catching an uphill edge can
be quite stimulating.
I've cut smaller radius coves with a shop made
1/16" parting tool, used basically the same way.
For the long sweeping concave cut I think you're after, a curved edge skew will do the job. Bottom of the linked page shows how. Note that the cut is started with the long point - with the long point down. The point is easier to control than an edge. Once the cut is initiated you can ride the bevel to control the cut.
As noted - starting a deep narrow cove off a vertical adjacent face using a skew or bedan can get tricky since a slight tilt of the edge in the wrong direction can get the edge to take off in the wrong direction.
The nice thing about turning is that there's always more than one way to skin a cat.
>I was wondering if I could do it with a bedan, that's all :). One of the ways that I try to "master" a tool is exploring its limitations. Turning a bunch of spindles is a good way for me to get the techniques into "muscle memory". Seeing how I have to turn a lot of spindles for this project, I figured it was time to really explore the bedan. I've use the bedan to part, size, cut tapers and roll beads for a while. I was wondering if I could use it to cut coves.
