Buffing question, What is white diamond?
>I have a Beal buffing system. I was wondering what White Diamond really is? Is it actually diamond grit or is is something else and we just call it diamond?
Is there any reason I can't use it for sharpening my tools? Could I use the same buffing wheels or would I need others? I think they would get dirty and leave black marks on my pieces of wood.
Re: Buffing question, What is white diamond?
Re: Buffing question, What is white diamond? *LINK*
Bill Howatt
>Tin Oxide in a wax binder. Link below explains a lot of different compounds.
I never use my Beall wheels for anything other than my lathe work. I buy (cheaper) smaller wheels for buffing other things. I don't know if it is necessary but it makes me feel better.
Bill
Buffing Compounds
Cyril Griesbach
>It's a reasonable question but I'm thinking it's just a finer grit and no diamond.
Rick Allen
>No Diamonds
This buffing compound is also called white rouge.
You will not improve the sharpness of your turning tools by buffing with white diamond.
You can sharpen cutting tools with these compounds.
I would use emery compound and a hard felt wheel.
Buffing compounds
diamond paste
JohnKJordan in East TN
IMHO the Beale wheels are good for polishing but way too soft and flexible for sharpening. The threads will whip around the tool edge and round it off. Sharpening needs a hard surface/backing. The Tormek sharpener uses a polishing compound on leather bonded to a hard wheel for polishing tool edges after grinding. Look at that edge under a microscope and even it is rounded somewhat, but I think that helps rather than hurts turning tools. Thin leather glued to wood with diamond paste is great for that final edge when sharpening knives.
FYI, you can buy real diamond abrasive in the form of dust, spray, or paste. These are made with carefully graded industrial diamond bits and are available from industrial supply houses, widely used in industry and research. Over 30 years ago I ran a one-man metallography lab and used a series of abrasives (sandpaper, aluminum oxide powder, diamond paste) to polish cross sections from nuclear reactor elements for microscopy. (We were confirming grain growth across bonded boundaries in an aluminum cladding sandwich, in case anyone cares!)
Diamond paste is great for hard things like the various carbides that other abrasives won't touch. It's a bit pricy, a couple of bucks a gram and higher, so you don't usually use it unless you really need it.
tek-Brunswick, Ohio
>I like the green chromium oxide for polishing tools. Don't use your beal buffs on metal, because it will make your wood dark gray if the wood isn't sealed all of the way. No! I don't want to talk about how I know that.
Dick Hines
Dick Hines
>It's something you don't want to get near dark woods like walnut
Walnut and white diamond
Dave Peebles Lyons, Ohio!
>Hi Dick,
I have heard this one forever. I have not found this to be the case at all. I always use all three on every thing I buff. I turn a lot of walnut and have not seen the problems others have experienced.
But I do use several coats of Waterlox on all my Walnut pieces. By the time I use the Beall system, I believe I have the grain sealed pretty well. I think the problem that some have are a direct result of a lack of enough coats of finish on the work.
Anyhow, didn't mean to single you out, but this one has been bugging me for a while. In my mind, it is a urban myth :)
Best wishes,
Dave
Re: Walnut and white diamond
>I think you are both correct. If you buff an unfinished (as in bare wood) walnut piece the white of the white diamond will show up in the pores. Actually, I am assuming it is the binder in the stick and not so much the abrasive particles, but it could be both. This would be troublesome if you were trying to buff the piece and then apply carnuba as your finish. If you apply enough finish to the piece to fill those pores and then buff the finish, that's different. You are buffing the Waterlox and not the walnut. In that case you don't want to buff through the finish and have a piece that is half Waterlox and half bare wood. BTDT.
