CA glue with spray accelorator
>I need to order some new CA glue for the club. I have been using EZ bond but I don't like their accelorator. I prefer the kind that comes in a pressurized can. It seems to last much longer. Does anyone know which brand that is and where I can buy in quantity.
Re: CA glue with spray accelorator
Ric Taylor
Ric Taylor
>John,
This doesn't answer your question, but I use Insta-Set accelerator, which come in the typical small spritz bottle, which is further packaged inside another clear plastic tube with a cap. When not in use, I keep the bottle inside the tube with the cap on, and I have no problems with evaporation. One two-ounce bottle lasts me way more than a year. I think many people discard the outer tube as if it is just packaging, but that is a costly mistake.
Ric
Bruce Wiseman
>I know that Satalite-City (sp?) now makes their accelerator in a spray can. I was told that they switched because the evaporation point is so low that you can loose all of the accelerator at about 95 degrees in the old bottles. I am not a chemist but maybe their accelerator works with any ca glue? If so you could mix and match.
Bruce
Charles Watson
>Stick-Fast
Re: CA glue with spray accelerator
>I buy whatever I am using at Wood Craft. If you need it, I will go to the shop and read the label. I don't know if they will see in bulk at a discount, but I doubt it.
I agree about the spray cans. Truly worthwhile. I have my CA in a drawer in my lathe cabinet. Not only did the accelerator evaporate out to the bottle, sometimes the increase internal pressure in the bottle from evaporation or vapor pressure force the liquid up the stem and out. On top of that, it made any CA in the drawer harden in the bottle. Apparently enough of the accelerator would inter the bottle through the open tip to harden it. Don't get the same effect with spray cans. On top of all that, the spritzer bottles were crap and you have to replace the sprayer occasionally. this is one case where the spray can actually is cheaper and better.
JohnKJordan in East TN
If I'm not mistaken, the instructions on mine said to remove the spray tube and nozzle and replace it with the solid cap when not in use. That's what I do and it keeps well.
But the old baromoter/thermometer syndrome drives me nuts with other things I would prefer to keep in a squirt bottle (the kind used in chemistry labs). I had danish oil all over the floor once after some extreme weather cycles - the bottle was practically emptied! This could have been a safety hazard if I had parked the squirt bottle on, say, a pile of cotton rags.
Wilford Bickel
>Highland Hardware sells the 12 oz cans.
Re: CA glue with spray accelorator *LINK*
Keith Newton
>Hobbytown USA has had Zip kick.
I have had this bookmarked, but not used them.
I have seen other discussions before, and while I don't recall what the other suggestion of a cheap over the counter product was, maybe acetone, I am pretty sure that Rick L was the one how knows. He post on this forum, and FWW regularly.
http://www.e-zbond.com/Product.htm
Jimiles-Charlotte, NC
>Try Klingspor
I need to buy in quantity from the source.
>Thanks for the responses but I need to buy in quantity from the source. Does anyone know the source of STik Fast or the other brand that uses the spray can. I also had problems with the spritzer bottles evaporating and had to store it in a seperate cabinet away from the CA glue.
Protection against UV?
Charles R. Smith from Victoria
>John, I was told that some of the commercial kitchen/ cabinetmakers like the pressurized cans because they block UV light which can affect the accelerators. They find that if they leave a container of the stuff in their truck, it degrades quickly unless in a lightproof can. I don't know whether this is true or is just an urban myth; I heard it from an acquaintance named Doug Black who runs a fine operation called Island Woodcraft. (However, if this is incorrect information, I take full responsibility for misquoting Doug).
Charles (who personally prefers the pressurized cans of the stuff)
Not what you are looking for, but... *LINK*
Ron in Drums PA
>It may help
CA
Thanks Ron, best price I've seen
Mike Nelson
Re: I need to buy in quantity from the source.
Keith Newton
>John, I misspelled the product in my above post. Here is a link to one that I like. I have only used the 2 oz spray can on the right side, but as cheap as he price for this 8 oz looks appealing.
Re: I need to buy in quantity from the source. *LINK*
Keith Newton
http://www.hobbylinc.com/htm/paa/paapt29.htm
>I'm too lazy/not anal enough to replace the cap every time. This was sort of a triple whammy. The spritzers got to hateful, as if they needed lubricating. Stiff and unpredictable to use. They either huffed and puffed and a squirted nothing or they gushed. Then the stuff would just disappear out of the bottle one it's own and if that wasn't bad enough the glue sitting in the same drawer would harden.
What I should have done was keep the glue in the refrigerator, carefully sealed in little vacuum sealed bags wrapped in two layers of opaque black coth that was UV rated, inside a plastic bag filled with activated charcoal to be sure my food was not given an odor or odd taste. The accelerator should have been in the original bottle with the original cap screwed back on it, first having filled it with high density glass marbles to raise the fluid level to the top and displace any oxygen. It should have then been filled with Bloxygen or Argon and the cap put on. The bottle should have been inverted and dipped in sealing wax that was just below the vapor pressure of the accelerator. This would then have been in a ziplock bag and stored two houses away in the neighbor's freezer with a little biohazard label on it.
I like the spray cans.
this is a must read. Great :)
Steven Antonucci
LOL
steve antonucci
