Oh yeah! I own a lathe!!!!
David Breth
>Last night, I was looking at one of my kid's toys - one of those horse heads on a stick that you "ride" by jumping around and being between the ages of 2 and 5? Well, "ours" was busted. The hollow plastic post that you ride got snapped. I looked at it, concluded that I might have a piece of dowling that would fit that hollow area, and would therefore be able to repair the horse. Ohhhhh, bad news. The dowling is too big. Hmmmm......now what do I do......then:
*BONK*
Oh yeah, I own a lathe! That thing I spend countless hours on two feet away from me. Ten minutes later I had a smaller piece of dowling that fit like a glove and horsey was repaired for his next adventure. I just thought it was funny in the respect that I always think of the lathe as a producer of bowls and other creative things. I completely forgot the more mundane "I need something round" functionality that the tool offers.
David B.
Re: Oh yeah! I own a lathe!!!!
Learn Somethin New Every Day! NM
ET
>David Ain't it great owning a lathe. Many years ago I was adding a walk in closet and I went down stairs to drill the hole for the door handle. I drilled the hole on the wrong side. Many cusswords later I remembered I had a lathe. I turned a plug to exactly fit the hole. Since the door was going to be painted it repaired it perfectly.
JohnKJordan in East TN
>>I always think of the lathe as a producer of... creative things.
Funny, it worked the other way for me. I bought my first lathe just to make a special dowel. I bought a cheap lathe to make a "trash" (tracing) paper dispenser for one son in architect school. Then I made a roller for an antique lawn mower and a few other utility items.
Some months later I saw the thing sitting in the shop, glued up some red oak boards, and turned my first bowl. I caught the dreaded turning addiction from that first bowl and went shopping for a better lathe!
But the new lathe still gets used occasionally for things in the non-turningforum-tradition - for example a dust plug for the hydraulic hose on my fence post driver, a froe handle, mallets, and rollers. BTW, a wood lathe also works fine to dress a steel shaft using a file, and make small things from non-ferrous metals and plastic.
Thad Parker
>I was in a pinch late on night with a leak on a hot water line below the valve at the sink. I had to shut the hot water off at the tank, which meant no hot water until the morning (unacceptable for various reasons). I was able to chuck up a plug that fit the cold water and hollow it just enough to cap off the hot water and turn it back on.
It held long enough to bathe babies, do laundry and dishes, and keep SWMBO from going to bed unhappy.
Oh Yes,
Don Henthorn Kyle, Texas
>I found my little Jet was just the ticket for putting a brushed finish on some 1 1/2" chimes I built. I wrapped the end of the tube with tape and held it in my scroll chuck. I got a piece of 150 grit sandpaper in my left hand, supported the other end of the tube in my right hand. Turned the lathe on to a very slow speed and had the aluminum tube perfectly brushed in very short order.
