cracks
cracks
cracks
Wilhelm Schmidt
>Sometimes, turned items develop small cracks after rough turning. The wood wasn't dry enough. I have heard that the cracks can be filled with glue and sanded over, essentially hiding the cracks. What kind of glue, and how soon after its application?
Re: cracks
Re: cracks
Cyril Griesbach
>Wilhelm, much of the cracking that you're talking about can be avoided by proper drying techniques and you can find lots of information on that by searching this and other woodturning sites. The glue you ask about is most likely CA (super glue) and while it won't hide the cracks it can help in preventing them from becoming bigger. Some folks will add sawdust from the project to help hide the crack and others will add a contrasting compound like coffee or tea grounds and many other things to accentuate the crack and make it a feature. I hope this helps.
Re: cracks
Re: cracks
Bruce Forrest
>I'd add a word of caution that if you are planning on coloring a piece, keep the CA away until after the dyeing is done.
Re: cracks
Re: cracks
Don in Central Illinois
>If the cracks aren't too big, you might try wet sanding. Using either water or a salad bowl finish, it will fill in the small cracks as you are sanding on the lathe. I've not used water, yet, but it does help using a bowl finish while sanding.
Re: cracks
Re: cracks
Rick Urban
>I just finished a walnut lid for a rather large cherry box. When I say finished, I mean I broke it on purpose it at the crack I thought I would be able to turn out of the final design. I didn't want to be tempted to glue it together... You will never completely hide a crack, disguise it, or otherwise prevent its discovery, so decide early if it is a fault or an artistic feature. If it's a feature, then there is another universe of discussion about how to deal with it. If it detracts from the piece, scrap it or finish it to keep in your own collection. That's where I keep some of my finest cracks because I just liked them. Just my $.02 worth.
Re: cracks
Re: cracks
Ken Grunke from SW WI
>I stopped using CA glue in favor of wet sanding with the varnish you'll use to finish the piece, working the fine sludge into the cracks.
CA stains the wood unless you seal it first with a varnish, and one day I was out of CA so tried the varnish instead and it worked well. Blends in better with the wood, and is more flexible. CA is very brittle after curing and may pop out after a while.
Re: cracks
Re: cracks
Allen Neighbors
>Wilhelm, I second what Ken Grunke said. Sanding with the final finish is a pretty good idea, unless it's lacquer. Lacquer dries too fast to make a good sanding medium unless you use quite a bit of retarder in it to slow the rate at which it dries.
If the crack is larger than a hairline, I wet sand with Danish Oil using 120 grit first, then graduate to the finer grits, wet sanding all the time. When you finish, the crack will be sealed over with minute fibers of the wood itself. You'll still see it, but it will be sealed. Sometimes I enhance the crack by using finely powdered coffee and either CA glue or epoxy. Epoxy is not as apt to come out, later...
