recent projects
recent projects
recent projects
eric_s
>I've received a lot of help and inspiration from the community here so I thought I would post some pictures of some recent projects. This is a mirror made from walnut. What is the best alternative to the liquid nails recommended in the catalog for attaching the mirror. I only did the one and really don't want to purchase an entire tube of construction adhesive. Is hot glue a suitable alternative?
The photography needs work. I am considering building a photo booth. Rather than the PVC/foam core combination I was thinking of using big sheets of corrugated cardboard (of which I have a virtually unlimited free supply) and painting them white. Would flat white be best?
Thanks,
Eric
Re: recent projects
Re: recent projects - sea urchine 4
eric_s
>Green sea urchin shell with cherry finial.
Re: recent projects
Re: recent projects - sea urchin 5
eric_s
Re: recent projects
Re: recent projects
Carole Valentine
>From what I can see, they look nice, Eric, but you've got to make the photos bigger. 500 - 600 pixels for the largest dimension would be a minimum. 80kb is the file size limit for WC.
Re: recent projects
Re: recent projects
Ken Grunke from SW WI
>Agree with Carole, your turnings look quite nice and need bigger pics. A textureless backdrop is best, and something that you can form in a long curve rising up at the back. Corrugated cardboard may show creases when you try to curve it but you could smudge them out with an image editing program. Washable vinyl banner/poster stock is ideal in my book, or window shades.
Re: recent projects
Re: recent projects
>Eric Liquid nails is the worst thing that I've tried to hold mirrors onto wood. I breaks free fairly quickly. I have used Clear Silicone Caulking for many years and many many mirrors.
Good job on the mirror, it's nice looking.
Re: recent projects
Re: recent projects - Biiger Pictures
eric_s
>Thank you. Here are some bigger photos. Max dimension was set at 500 pixels.
Re: recent projects
Re: recent projects - Biger Pictures
eric_s
Re: recent projects
Re: recent projects
eric_s
>Ken -
Thank you.
I was planning on a window shade(if I can locate one) or splurging on an actual photo backdrop to use for the actual image background. I am thinking of using the cardboard to build the booth enclosure to contain/bounce the light off of, painting it flat white in lieu of the foam core panels in the phrugal photo studio article? The size of the cardboard I can get will also allow me to make the booth larger than the one in the article - although I am not sure if that is a good or a bad thing.
Eric
Re: recent projects
Re: recent projects
eric_s
>John -
Thank you, it was seeing a post of some of your beautiful mirrors that convinced me that I had to try one.
Eric
