>Hello, I am trying to get my dust collector set up and someone told me that you can use carpet rolls for straight runs. Anyone here tried that? Pros or cons? I was concerned about static but he said that he ran ground wire through it and it was all OK.
>I'd rather use schedule 40 or schedule 20 PVC. You can glue them much more easily and find fittings for them for drops and other things. Carpet rolls may be less expensive, but schedule 20 is still relatively cheap.
>I used the gray PVC which was not very expensive. Rather than glue I used duct tape so if I ever needed to move the pipe around I would not have to cut.
>Heather, I'm sure you could and I wouldn't be concerned about the static, but I doubt I would. As I recall, carpet rolls are rather thick walled and what you want is large inside diameter. Also, you probably would have trouble finding fittings etc. Check out S & D or Sewer and Drain pipe for the Borgs (Lowes and a better selection that HD, locally). Also check out farm supply places, they were even cheaper, but had also no fittings. I don't remember, what I paid, but the pipe, Especially the four inch was cheap. And lighter in weight that the carpet rolls I am familiar with. I thought it was schedule 35, but it may have been schedule 20. I think the idea that the DC will collapse ducts and plastic pipe and the static myth have been pretty well disproved for home sized systems. Check out Bill Pentz's site also. There is way more there than you want to know, Including how to make your own fittings.
I would be concerned with pressure drop through the carpet rolls. Although straight, I recall that the inside is just exposed card board which is a rougher surface than the PVC or metal duct. Rougher surfaces will result in more frictional losses and less collection efficiency, which becomes an even bigger issue when you use 4 instead of 6 inch diameter duct.
>Thanks for the tip on Bill's site Barry, there is a lot of good information there. Having just upgrading to a newer cyclone system the site is very timely.
The static around here in Maine in winter is wicked, I get shocks turning off the lathe, and the switch is insulated, so just in case, I ground my system.
