Two small apricot burl turnings
Eddie Pacheco, San Jose, Ca.
>Last Sun. Troy German stopped by with two pieces of apricot burl for me. He also brought along his chainsaw and we cut the pieces to manageable size. This wood had been sitting in a wearhouse for a long time so there was a fair amount of checking on the ends. Last night and today I turned these two small forms from some small chucks of the burl. The little bowl is 1.5" dia. x 1.25" tall. The Osolnik inspired piece is 5" tall and 1.25" di. at the base.
To fight tearout I used the skew on the outside, but then I also tried the Hunter cutter to see how that would work. It worked quite well, not as good a finish as a skew, but no tear out either. I also hogged out the insides with the this tool and I really like the results. I took John's suggestion of keeping the tool angled at about 35 degrees or so and I get nice shavings. It will catch, bigtime, if you straighten/level it to ride the bevel. At least for me that was the effect. For me this cutter insert and improved skill with the skew has really helped. I have way less sanding time.
Re: Two small apricot burl turnings
Nice looking pieces Eddie
Gil Jones on Lake Seminole GA
Re: Very nice- I've never seen .....
Jamie Donaldson
>... apricot burl before. How big does an apricot tree grow, and how big was the burl?
You're asking me?
>Jamie,in my neck of the woods these trees have been torn out long ago to make way for tilt ups, houses, strip malls, Silicon Valley in general. One of the pieces he brought was about 45-50# (wait a minute, I was carring it. it was 80-90 lbs...:-) ) and the other was about 35#. The OD was about 20 inches or so.
Troy lives in Chico which is still agricultural so he may have a better idea as to what size these will grow to, and will chime in later. It's raining here now so I can't go out to take a picture of the pieces.
Wow, that was fast!
Troy German
>They look good. I�m glad the Hunter tool worked well. Hopefully you can get a couple more good turnings out of that wood.
By the way, thanks for letting me stop by. I enjoyed it. I�m still impressed with how quiet your 3520 is.
As far as apricot trees go, I think that an 18� diameter at the base is about average for a full-grown tree, but my sense of size has never been very good. They are very much like almond trees if that helps at all. I�m guessing that this tree came from someone�s yard as orchard trees are too pampered to grow interesting things like burls.
Thanks again for the visit, and good job on these turnings.
Troy
Re: Troy- you're a big help when....
Jamie Donaldson
>.. you say that they grow as big as an almond tree!! So how big does an almond tree grow to be?? You have to remember that us midwestern folks have never seen many of these exotics of which you speak!!!
Ace Foster in Port Orchard
>Think apple or cherry trees. Mostly apricots are grown as orchard trees that get torn out before they get real big. A foot and a half would be pretty fair size. Marvellous lovely wood, if you can keep it from checking.
Allen Neighbors
>Jamie, when I was 5 years old, we lived in Modesto, CA. My dad was foreman on a Peach Ranch. We also had an Almond orchard of about 10 acres next to the house. I can remember they spread tarps under the trees, and my 14 year old brother and some other guys would climb up into the trees and beat the limbs with large rubber sledge hammers, to shake down the almonds. They drove a flatbed 38 or 39 Ford truck (with the top cut off the cab) under the trees to pick up boxes of almonds. I think the trunks of the trees were probably 18-24 inches thick. (that was a long time ago)
Section of apricot
Troy German
>Maybe this will help. I tried to find a good picture of an apricot tree online but it turns out that the blossom and the fruit are much more photogenic than the trees. Same is true for almonds. I did find some interesting facts about almond orchards though:
There are over 600,000 acres of almond trees in California.
When in bloom they need over 1,200,000 beehives to pollinate them.
80% of the worlds almonds are grown in CA
99% of U.S. almonds are grown in CA.
Troy
Re: Section of apricot
Troy German
Ron McKinley
>Apricot is a beautiful wood to turn but haven't turned any burl.....Ron
