When you are stupid you are suppose to suffer.
Dick Hines
Dick Hines
>I had the day and after some yard work I started to turn some bottle stoppers for a gallery tour this weekend. Every thing was going great until key chuck decided to unseat from the headstock. I had just finished sanding the stopper and put a friction wax on. Not wanting to start over with the sanding if the chuck dislodged I hit with my hand. STUPID!!!!. I now have three fingers that are ground down.
The next time the key chuck wants to run off some were I will just let it go.
Re: When you are stupid you are suppose to suffer.
Keith Tompkins
keith tompkins
>Bummer, Dick. Many chucks are threaded for a draw-bolt. If your lathe has a hollow spindle, it solves that problem.
Mike Stafford
Mike Stafford
>Dick, that sounds painful. Let it go, let it go. Get out of the way but let it go.
Carole Valentine
>Dang, Dick. How bad are your fingers? Did you have to go to the ER?
Dick Hines
Dick Hines
>No ER for. Just some paper towel pieces and masking tape.
eliot d
>Try to get hold of the September 2005 issue of Woodcraft magazine. On page 37 there's a five page article (Project 18) called "Shop-Made Collet helps you GET A GRIP". It's an extremely easy turning project designed to make a chuck specifically for turning bottle stoppers; and, of course, it can be used for other small stuff. There's no way you could get hurt using one of these.
Dick Hines
Dick Hines
>Bet I could.
eliot d
>Well, it's a wooden chuck, so it's at least less likely. Glad you weren't hurt bad.
Rick Urban
>Glad you weren't seriously hurt. I salute your courage in letting us know, too. (I have too many red badges of courage ane too much cowardice to share here.) That's why I, too, get nervous about JT33 tapers and 2MT tapers being the only things that hold the stuff to the spindle. It all led me to doing bottle stoppers with a 3/8" 2MT collet which I am quite comfortable with.
Dick Hines
Dick Hines
>Rick, I learned to turn by the blood letting method. This is not the first time I have lost shin, meat and blood to the lathe gods. I was lucky I did not do more damage. I got back on the horse this afternoon. I turned some more bottle stoppers.
