Thanks Ellis, John Lucas and others too
Mike Brazeau
>This site is simply amazing! Yesterday on our way back from totally Turning we stopped into the Woodcraft in Rochester. Some amazing force drew us to it from the NYS Thruway and it was only a few minutes drive. I almost shouted with glee as I found a pretty good assortment of the Hunter Tools and a few cutters. I have been following these threads on the Hunter Tools and chomping at the bit to try them. After some thought I bought a #3 cutter knowing of the discussions which have taken place over the past couple of months. Hopefully it is a good starting point. Now I have to round up a drill, tap and screw and make a holder from some of my steel supply.
I just cut and pasted several pages of posts into a Word document, mainly by John, Russ and a few others that have been trying them and should easily be able to get something together.
What an amazing time to be a wooodturner and one that likes to make tools too!
Re: Thanks Ellis, John Lucas and others too
Peter Hyde
>So Mike are we going to see it on Thursday night?
Mike Brazeau
>Hi Peter.
After being away for the four day weekend and we are babysitting next week while our daughter flies to Japan to join her husband on a business strip, I think this week will be limited to planning only, maybe fnding the supplies at an industrial supplier. Also have a couple of bowls to finish off for a benefit silent auction at the end of the month. I may bring the cutter itself, since our topic is hollowing.
So what line of work
Bruce Lane
>requires a business strip? :-)) So glad to see there are others with big fingers out there.
Jennifer@Indy.USA
>Mike,
I just bought one today too! Can't wait to play with it.
Jen
Ed Heuslein
>Interesting. I intended to post a question this evening and here is the subject already. I have two of Mike Hunter's tips (#1 & #4). Each size seems to have a different sized screw. They are metric, with a slightly tapered head, similar to a wood screw. Knowing myself like I do, I already am assured of losing some screws (don't go there). Mike gets $4.00 each - yeah, four bucks, not forty cents. I've checked and they are not made of gold. I can't find any fastener supplier who has ever seen such an animal, let alone stock them. Anyone know where we can get them? Thanks. Ed
You can use a 6-32 screw for the #3
Eddie Pacheco, San Jose, Ca.
>In case you have trouble finding a Torx head metric screw, you can substitute a socket flat head 6-32 screw to fasten the #3 cutter. I used a modified flat head screw and I have had good results so far. I did have one instance where I didn't lock down the screw and the cutter came loose and I got a catch. The inside dia. of the Hunter insert is not tapered and instead had a bit of radius to the profile. The head of the screw clamps down on the tiny ridge or ledge transition between the straight, shallow side wall and the contoured taper.
For the larger #4 cutter I used an M4 socket head cap screw as well.
As you can see from the pic. the OD of the screw head has been reduced to fit the insert' shallow counterbore.
>There are quite a few places online that sell the screws. Just do some searches. I haven't had any trouble with mine coming loose and there isn't any real reason to remove them unless you have to replace the tip, and that should be a long time coming.
Torx Screw Sources
>I did a quick search for online sources for these and didn't find too many sources. There are a lot of sources for the tamper proof Torx screws. I'm pretty sure I've seen them at the auto parts stores.
Wow, there is a heck of discrenpancy in prices! Probably quality too.
I think the time spent searching either online or driving around probably justifies the $4.00 ea. charge from Hunter.
http://www.aaronstorxscrews.com/cfusion/SearchResults.cfm
http://www.knifekits.com/torxscrews.htm
torx screws *LINK*
>I did a quick search of Small Torx screws and there were several places listed. I've bought things from them before and they are good to deal with. One other thought. You end up paying a lot of shipping cost at many of these places. I remember one time paying $5 shipping for a .39 part. I had to have it and they were the only ones. You might run into the same thing with the torx screws. It makes Mike's price seem a little better.
http://www.smallparts.com
