Banksia seed pods.
Banksia seed pods.
Banksia seed pods.
Woogie
>How do you stop the "red dust" that goes all over the place when turning banksia seed pods? I use a dust collector directly behind the lathe but the cloud still escapes into the shop. Is there anyting I can spray on before I turn to cause the red fibers to clot so they don't go all over?
Re: Banksia seed pods.
Don Evans
>I think you will find that your problem can be cured or at least helped if you use a hood made for dust collection that wraps around the piece. Check the dust hood made for pen turners or anyone turning small objects on the PSI site Penn State. Others sell it also, believe Woodcraft carries it.
If all you are using is a hose with funnel in it, it will take one monster dust collector to move enough air to do what you are asking for. The enclosure around 3/4 of the object makes even a modest collect much more efficent.
Don
