Bleaching turned wood
Bob Rogne
>I have seen a number of posts that say the wood is bleached and then whatever(carved, burnt or).
What is used to bleach your wood?
Bob Rogne
Bob Rogne
Bob Rogne
Kleen Strip Two part wood bleach
Carole Valentine
Ditto
steve antonucci
Re: Ditto
Bob Rogne
>THANKS Carole and Steve
Will pick some up next trip to the big box.
Bob R WestMac Turning
Re: Kleen Strip Two part wood bleach
Barry Turner
>Does that work better than Oxalic Acid?
Leppikallio
>Because these are not available around here (bleaches for wood) I have to ask some stupid questions.
Could these two part bleaches be something similar than those used to bleach hair? Before use you mix hydrogen peroxide and oxidant and brush that mixture on the wood? How long do you have to wait to get "bleached" effect? Do you have to wash the piece after bleaching (does that bleaching mixture dry on the wood)?
I have quite good source for (professional) hair bleaching products (please don't ask) and I have indeed made some tests. The biggest problem so far is that these products do dry on the wood should be washed away. However it just doesn't sound that good to wash ready, dry, piece of wood?
DaveL
>Try Woodworkers Supply at www.woodworker.com
That's where I get it from
Dave
Re: Bleaching turned wood
>Bob I use a 2 part wood bleach that I bought at the local hardware. I think my local paint store carries a different brand. I can't seem to remember the brand this morning. It's easy to use, you just mix the 2 parts together and rub it on. I usually takes multiple coats.
It raises the grain so I wipe the piece with water, let it dry and sand lightly with 600 grit before I start. The bleach only penetrates the wood a few thousands of an inch so it's easy to carve through it. It's also easy to sand through it so keep your sanding to a minimum. If you use more than one coat they tell you to neutralize the piece with white vinegar.
I find that it takes overnight to really tell how successful your bleach is. It gets lighter as it dries. Also all woods bleach differently and some don't go white, they change color. Be sure and do a test on anything serious. Most of the common woods like Oak, Ash, cherry, walnut, hickory do bleach lighter but Osage Orange changes to gray. I haven't tried it on any exotics yet.
Don't know about hair bleach...
Brian Hahn in SW Wisconsin
>... But the two part bleach is very simple. First apply a weak sodium hydroxide (NaOH, lye, caustic soda, etc.) solution to the wood. The commercial kit is 5-10 gm per 100 ml. This seems to have two effects, the most important is that it will de-activate the stabilizer in the hydrogen peroxide solution. I normally let it dry. Then apply a hydrogen peroxide solution. The 3% solution available here in drug stores as an antiseptic will work, but a more concentrated solution will work faster. Let dry. Repeat the hydrogen peroxide application until you have the desired effect. Rinsing the wood afterwards is optional and I never bother because I don't see a technical (chemistry) reason to do it.
Keith Newton
>Oxalic Acid is good at removing metal stains, like from a nail in oak that has gotten wet, but it won't turn the wood white like the two part.
When you do the two part, and use multiple coats where it gets really white. What is left on the surface is just the hollow cellulose cells of the wood, after all of the mineral extractives have been removed. It looks a lot like a Kleenex tissue, and is about as fragile.
>Most interesting Keith. I had not thought of it that way. I haven't had a problem with it being weak that I could tell. I'll try to pay more attention to that detial when I do the next piece.
Rick Allen
>Hydrogen peroxide (35%)
You want to do this outside because there is a heck of a reaction. Avoid breathing the fumes (there WILL be fumes) so being upwind is a good idea.
This works fast and fairly deep (considering it's a surface prep). 35% Hydrogen peroxide is the stuff that us used in paper pulp factories. There is a long history of using this product to bleach wood.
eliot d
>I don't usually take the time to go down to my shop to look things up.....but for you, here it is: Klean-Strip Wood bleach. Two part stuff; works like magic! ( Be careful not to tip the box; one of the bottles has a vent hole , so it will leak if not held upright.)
eliot d
>Just noticed that others have already told you. (My package spells it 'Klean' -- not 'Kleen'.)
Steve Worcester
>Kleen Strip works ok and is locally available (if you live in the Dallas area, I will give it to you), but the Hoodbleach 190 works much better. It is pretty powerful and will pit the wood if you get too agressive with it. And you DO NOT mix the two liquids. You brush on part A, wait 5 minutes (and you want to wait) and then brush on part B.
http://www.hoodfinishing.com/wood_toners.htm
Re: Don't know about hair bleach...
Ken Grunke from SW WI
>Thanks for that info, Brian.
In '92-94 I worked for a fiberglass sculptor who bought resin catalyst in gallon jugs, which happened to be industrial-strength hydrogen peroxide.
So if anyone's getting serious about bleaching, you might want to look into that.
Rick Urban
>After looking at all the posts not only agree with recommendations for the Klean-Strip product, but I wonder if anyone has tried Drano (NaOH) and Peroxide from the grocery which are the main ingredients mentioned on the Klean-Strip containers. (BTW... Don't waste your money on the one part bleach for wood that may be the only product carried by your local home improvement center.)
Clorox
Jorge Castaneda
>Peteri,
You are right, one of the 2 parts bleach is Hydrogen Peroxide (I don't know what concentration), and the other I think is Lye.
Clorox, the stuff we use for bleaching clothes works well too, maybe not as strong as the 2 par; if you use Clorax, you can give it a second application, works great right in the sun, the wood changes color right before your eyes. Once you like it rinse the stuff and let your wood dry.
Jorge
Oxalic Acid
Jorge Castaneda
>Oxalic acid is another chemical that bleaches wood, not as strond as the 2 part, sold as wood bleach in paint stores, also in plumbing stores, as rust stains remover.
You mix some powder with boiling water and use inmediately; it is odorless and colorless, so discard at once so children or pets or yourself dont drink it, it could be fatal.
Work, but slowly
>I've used the original Drano (around here the new stuff isn't lye) and 3% hydrogen peroxide from the grocery store. It didn't work as fast and took more applications of the hydrogen peroxide, which is what you'd expect. But it did work quite well and for a lot less money.
Re: Work, but slowly
Bob Rogne
>WOW
Thanks to everone.
Spent the last two days with the heart doctors and so have been out of touch. So thanks again for all the info. Will be getting back to the shop in the AM.
