Axminster Eccentric Chuck *LINK*
Wilford Bickel
>Has anyone used the Axminster Eccentric Chuck that is sold by Craft USA? Specifically can it be used with a Super Nova Chuck. I would also appreciate any impressions on how good the unit is from someone that has worked with one.
Thanks
Wilford
Eccentric Chuck
Re: Axminster Eccentric Chuck *LINK*
Craig Daymon
>I just bought one recently. I like it, but it's not a Escoulen. There is no tilt configuration, only offsetting of the center with 12 position indexing. I finished (except for the finish) my first piece with it just yesterday. I'll try to post pics after I slap some finish on it.
I expanded #2 OneWay Talon jaws into it and it worked fine. I'm guessing the Axminster jaws might have a slightly better fit, but I didn't have any problems. I would imagine your Super Nova should work fine.
I'm thinking of ways to make variations on the Axminster using baltic birch ply and faceplate rings, like those sold by Axminster and Vicmark. The level of eccentricity of the Axminster is enough to be useful, but somewhat limited. Though more might be dangerous with this method of securing the chuck.
My first project puts an eccentric plug in the bottom of a shallow bowl. The plug is turned identical to the Sauracker shell described in Mike Darlow's 2nd book.
-Craig
P.S. The Escoulen Deluxe chuck is on closeout at Craft Supplies. Still twice the price of the Axminster, but much more capable and ove $100 less than full price. I think only available in OneWay spindle size...but maybe with an adapter?
Allen Neighbors
>Wilford, check your 50mm jaws on your SN2. Open them, and measure the outside. If they expand to 2-3/4" you should be alright. (I can't remember what mine open up to>)
Wilford Bickel
>That helps Allen, I was not sure from the write up if it was the inside or outside jaw measurement. I think mine are going to easily be 2 3/4 on the outside opened up some but will verify tonight.
Thanks
Gordon Seto
>"P.S. The Escoulen Deluxe chuck is on closeout at Craft Supplies. Still twice the price of the Axminster, but much more capable and ove $100 less than full price. I think only available in OneWay spindle size...but maybe with an adapter? "
Both Escoulen chucks use Oneway Stronghold chuck inserts. You can change the insert to fit different lathe. They are not recommended to use with smaller lathes, especially the Deluxe. There will be too much stress on the bearings. The light weight lathe can't handle the off-balance load. If the lathe has high minimum rpm; very little off-set would cause the whole shop to rock.
Gordon
Fog Tanner
>I have both chucks, and the small one does indeed use a Oneway insert. Unless they have changed something in the larger one, the ball is threaded with no insert. At least the one I have on my lathe right now is like that. I don't think I would want an insert in this one as much as I am already pushing it.
Fog Tanner
>I am not sure you would want to use an adapter on the large Escoulen chuck. It is already a fair amount of steel rotating around off axis. When you have the piece offcenter and eccentric, you have a large amount of mass rotating around the spindle. That is one reason that the large chuck only came in three flavors, 1 1/4"x 8 and the two large metic verions. The piece I have on my lathe now, with the chuck settings, would launch a jet mini if it could rotate. And with the extreme settings you have a lot of leverage trying to find the weakest point. An adapter would just put it that farther away from the headstock and increase the leverage.
Overall it is a fun chuck and I would not trade it, just wish I had one that would do larger pieces. Somewhere between this size and the one that Kelton makes, which is too large for what I like to do.
Gordon Seto
>You are correct, the Deluxe is direct threaded to the ball. There is no insert to change spindle size. I think you have to change ball with different thread.
My apology. I should have gone out and look.
BTW, Escoulen has another new eccentric chuck that he demonstrated at the Yankee Symposium. It has counter balance like the big Kelton. You have to get it direct from him.
Gordon
Fog Tanner
>Gordon,
I had heard that there was a new one out, but have not seen it. Does it have the ball setup like the other two or is it for offcenter only. The counter balance will definately be a plus. I have a Vicmarc 300 and Vic has come out with a balancing system designed primarily for their lathe, but should work on a number of other lathes as well.
I have bought one, although it is somewhere in the Pacific on a ship still a few weeks out. I did get a look at one mounted on a Vic lathe in Wichita Falls recently. It is mounted outboard and has two eccentric weights which fit on a short shaft that is screwed on the outboard adapter. The weights may be arranged to balance out the piece and then easily changed as you reduce the off balance mass. I bought one for use with the Escoulen chuck as I like to get the rpm up over 1000, preferrably around 1500 when I can.
Along with buying the balancing system, I got a good look at the Vicmarc oval turning device (VOD300). I told Christian if I could ever afford one, I would like to put the Escoulen chuck on it. That way I could turn a piece that was eccentric and offcenter and have it come out oval was well. With all that whirling around, it would definately not be for the timid.
BTW, you might pass on to Doug that his tools got a lot of good press even though he wasn't there. Apparently there are some sales in Texas outside of Houston.
Fog
