Nice chunk of Wild Cherry
Julie
>I really want to turn this rather large piece of cherry but the bugs liked it too. Is there a way to make it stable to turn, It has bug holes in it and some tracks where the termites were residing too. It has lots of spalting. Didnt find anything in the articles section.
Thanks for your Help..
Re: Nice chunk of Wild Cherry
Steven Antonucci
What makes you think it can't be turned normally?
steve antonucci
>Without seeing a picture, I wondered why you thought it might be unsafe as is? I turn lots of wood with spaly and bugs and it's usually insignificant relative to the "stable" wood.
What concerns you?
Steve
JohnKJordan in East TN
>>Is there a way to make it stable to turn...
By "make it stable" do you mean keep it from flying apart? A friend of mine turns some amazingly fragmented large chunks of wood by turning the outside, wrapping with a few layers of strapping tape, then turning the inside. The strapping tape keeps the thing together. Some of his pieces seem like more air than wood!
Re:Put some masking tape on .......
Jamie Donaldson
>... before the filament tape and you won't have any sticky residue when finished- a neat trick I learned from Rude Osolnik years ago.
How about stretch wrap? *LINK*
Craig Daymon
>The stuff they sell at U-Haul stores, and probably the big boxes. You can get it in about 3" widths, as well as several other widths. No adhesive to worry about. I haven't put it to use yet, but I bought some, along with a simple handle, for just such purposes. Basically Saran Wrap on a stick. I think I bought it from Enco. The link is below.
-Craig
Enco Bundling Stretch Film
Re:Craig- I haven't heard from any....
Jamie Donaldson
>... user whether this material continues to stretch when applied in this manner? If it does stretch it would negate the reason for using it in the first place.
Not enough to matter...
Brian Hahn in SW Wisconsin
>I've used the packing film to secure things while turning, including wrapping it around the turning and chuck to keep everything solid. I stretched it pretty good as I put it on and it held very securely. I'd say it is better than masking tape or duct tape because 1) it conforms to odd shapes better and 2) it doesn't leave a residue.
