question on finishing lignum vitae
Ed Mackey
>I just purchased a piece of lignum vitae and turned a finial. I sanded from 150 to 600 and it appeard totally finished....even had a beautiful satin luster. I then applied a coat of satin poly urethane gel, my normal finish for turnings, and as I wiped it off with a paper towel, the moist gel on the towel turned blue. Is this normal ? Also, is there a better alternative to the poly for this wood..ie danish/tung oil ?
Thanks
Re: question on finishing lignum vitae
Allen Neighbors
>Ed, I just chased some threads on a piece of Lignum Vitae. It's the first piece of it I've ever turned. But just from turning it, I've decided that it will be a finial without a finish.
Lignum Vitae is used for the prop shaft bearings in large ships, because it has a built-in lubricant, and never wears out. It will do fine without an artificial finish, but with just a good buffing. My .02. :-)
eaglesc
>LIgnum Vitae was used for the gears in wooden clocks because of it's lubricating properties.
Also used for wringer washing machine rollers and bocce balls.
I believe the last use as bearings in ships was up until WWII subs.
Jorge Castaneda
>Ed,
For centuries lingam vitae has been in use for blocks in the running rigging of sailing ships, also for parrel beads, dead eyes etc. never finished with anything.
Jorge
Here's what I've done...
>Absent any kind of finish and exposed to the air, light and heat, lignum will develop lots of little surface checks and possibly some larger and deeper cracks over time. Normal finishes are not worth much on lignum because it is so dense; the finishes can't penetrate well enough to grab hold or protect very well.
Here's a trick that works great for lignum mallets and finials and such. First, melt some paraffin in a double boiler (preferably in the driveway or someplace very fireproof) and have a cheap paintbrush handy. Put a fan tip on your propane torch and heat the surface of the lignum evenly until you see little brown beads of resin starting to come out of the surface of the wood. When the whole thing is sizzling, brush the surface thoroughly with melted paraffin. The cooling wood draws the paraffin down into the surface. When it has cooled, simply buff the brown resins off the surface and you're done. It will turn the wood to a yellowish brown-green, but the dark greenish black color will return over time.
As with any finish, try it on scrap first to make sure it will work and look the way you want. My mallets show no sign of crazing after many years of exposure and use.
Ellis Walentine, Host
