>I"ve seen the posts regarding making allen wrenches, etc., into good ornament hollowing tools. I don't doubt making your own tools can work well, I just barely have time maybe once a month to do any turning. I don't want to spend my time right now making a tool.
What tool would you recommend for ornament hollowing? I only want the tool for ornaments, so I don't care about multi-use, etc., just something that works well. I also don't care too much about price, it it's "reasonable" at all... I'd like something that can either be sharpened without some special jig or setup, or an easily replaceable tip.
>Larry I can't recommend a tool because I make all my ornament hollowers but it only takes me about 15 minutes to make one. Not counting the handle that is but a handle for an ornament hollower can be as simple as a broomstick with a hole in the end.
I use 5/16 drill rod that you can get from www.use-enco.com. I use 2 tools mostly a straight tool and one with a 35 to 45 degree bend. I heat the tool with a propane torch to red hot at the point I want to bend it. Then I bend it. The drill rod is hard enough you really don't have to harden it but I do because you don't have to sharpen it as often.
At this stage I rough grind the tip because the metal is softer.
To harden the metal Heat it red hot until a magnet won't stick to it. Then quench it in water. I should tell you that I buy W-1 drill rod which quenched in water. The 0-1 drill rod is oil hardening. The red hot quench makes the tool too hard so you have to anneal it which takes away some of the hardness. To do this I simply put it in the oven at 425 degree for 30 minutes and then let it cool down.
You can do it all with a propane torch but you have to polish the metal after the hardening process and then reheat it to a light straw color. It's very easy to overheat it so generally I just take it to the oven. I can make the handles while it's in the oven heating and cooling. I'll post a photo in a few minutes. I have to take the Great Pyraneese puppy I'm dog sitting or a walk.
>The top one is the bent tool and the bottom one is the straight tool. These are 5/16" I also have a 1/4" set and 3/8" set. I think the 1/4" is too small and chatters on bigger ornaments. The 3/8" gets hard to hollow through a 1/2" hole but is handy for deeper ornaments.
>Here is a close up of the tip. It's very easy to grind. The bent tool eventually gets shorter and shorter as you sharpen but it's very easy to re-heat-bend and reharden when it does get too short.
>My best one is an allen wrench style, and it has a flat where it sits on the toolrest, keeping the torque down just alittle. I have also marked mine to the depth of the ornament. All mine are close to the same size, but there has been a few times I've hollowed through the ornament into the waste block. Sorry for the terrible pic. Still don't have a good camera.
>Larry, I think the reason most folks make their own small hollowers is because there aren't any available for that small of work. At least none I've ever seen. I have a small hollower made from an allen wrench that will hollow through a 1/4" opening. I made it to hollow tagua nuts for ornaments.
>Thanks John, and everyone. I may give making one a try, just very hard to get any free time at all, and I'd like to spend it turning when I can.... Larry
PS - John, the details on how you do your tools was great!
>Local Woodcraft store used to have a set of three that were the right size for ornaments. I think they were Sorby and were about $115. They were straight, angled, and a swans neck. The steel was bout 1/8 or 5/32. They were very nice, but I thought a bit expensive, so I made my own.
I did not anneal mine. I just heated them and quenched them. Supposedly at that stage, they are possibly glass hard and brittle. I just slammed them down on the cast iron bed of the jointer as a test and they did not break. So I use them as they are.
>I bought and use the tools from Robert Rosand for my ornaments. I also use two similar tools that I bought from Mike Hosaluk. I tried the allan key thing; it worked, sort of, but not as good as the tools I bought.
>I will second Bob Rosand's tools. I made my own and use it often. The HSS cutter lasts a long time. If your into silver soldering, they aren't hard to make.
