sandpaper
Julie
>just starting to turn wooden bowls, had some logs out back for at least 2 years. Pretty dry now. where do you all buy your sandpaper? Lowes etc is a bit costly. I did look at Russ's corner. Great Site.
sandpaper
Julie
Re: sandpaper *LINK*
Brian Hahn in SW Wisconsin
>If you are looking for sheet sandpaper, both Woodcraft and Home Depot carry Norton 3X in the 20 sheet packs for about $10 (coarse grits are slightly more).
If you are looking for sanding disks, many people have their "absolute favorite" at the "absolutely best price" online sources. The best quality/price compromise seems to be to make your own disks from the large sheets (36" x 1m) of sandpaper from Industrial Abrasives. (www.industrialabrasives.com) There's an article in the WC Articles section about cutting this sandpaper at the link below.
Sanding and Sandpapers
Re: sandpaper
Bill Hale
>I use Klingspore J Flex fabric back. I buy it in rolls 3" wide. You can fold it with no loss of grit.
When you use any sandpaper use it as if someone else was paying for it. Don't try to strech its use.
Good turning and be safe
Bill in Show Low AZ
Re: sandpaper
Barry Turner
>Don't be tempted to skimp by buying cheap sandpaper. This is false economy. This is one of those cases where you usually "get what you pay for". Quality, name-brand sandpapers (like Norton or 3M), last much longer and cut much better than cheap no-name sandpaper, so what may look like a bargain, may not be.
Buy several different grits to start. You will probably need to start with 100 or 120, then go to 180 or 220 and then to 320 or 400. Different woods require different strategies. As your tool work improves, you may be able to start with a finer grit like 180. Don't be tempted to skip grits. Work your way through them progressivly.
Don't try to use the same piece of sandpaper for too long. This is also false economy. New (sharp) sandpaper cuts better. Worn-out sandpaper no longer cuts well and tends to cause excessive heat build up, which can burn the fingers and also cause the wood to heat check and crack. It helps if you back up hand-held sandpaper with a pad of Scotch Brite or some similar product. Sand with the lathe running at slower speeds, say 1000 rpm or less. This allows the sandpaper to cut better and also avoids excessive heat build up. Worn-out sandpaper can also tend to burnish the wood, which can cause finishing problems. Someone once said, (a woodturner, no doubt), "Use sandpaper like someone else was buying it."
At some point in your bowl turning experience, perhaps very soon, you will want to investigate power-sanding with and electric or cordless drill. I use an old Panasonic cordless with a top speed of 1500 rpm, which is about right. You use 2" or 3" foam pads with velcro and velcro-backed sandpaper. You sand with the lathe running slowly, say 500 to 600 rpm. It works wonderfully and is much faster than hand sanding with sandpaper. The finish is also much smoother. Good luck.
Oops!
Barry Turner
>Now, I know who said "Use sandpaper like someone else was buying it! It was Bill Hale!
Re: sandpaper
Dick Hines
>Julie, here is sight that has great sand paper.
www.vinceswoodnwonders.com
These are the best disk I have ever used. Long lasting and don't clog easily.
Talk to him if you want to order a large quanity for a club.
Re: I second the vote for Vince.
Allen Neighbors
>You can't deal with any better service than him, either.
Re: sandpaper
Jimiles-Charlotte, NC
>Klingspor. Our Club meets there in Hickory N C
They are the manufacturer. They sell it by the pound in the store and I think also through catalog.
Re: sandpaper
eliot d
>I have found the best sandpaper to be AstroDot. There's a Canadian company called Woodchuckers that sells it. It doesn't even look like "ordinary" sandpaper. Try it. you'll like it. ( No affiliation.)
Ditto
Carole Valentine
>I also like his cloth and foam backed rolls. Good for contours and sanding inside hollow forms with forceps.
