Re: What Parting Tool
Donna Banfield
>Hi Bob
For your pepper mills, you would want a very thin parting tool, 1/16th. I use the Crown 1/16th, but there are several manufacturers that make that size. The reason you'd want it very thin, is assuming that you'd want the wood grains to line up when the mill is put together, a thinner kerf won't take as much wood as a thicker parting tool. The disadvantage to a thinner parting tool is the depth that you can effectively reach -- the thinner the blade/metal, the more likely it will flex.
On bottlestoppers, I suppose that you could use the thin parting tool to clean up the bottom or face of the stopper blank, where the wood meets the stopper (silicone, cork or metal), but if there was any wood surface showing, you could also use a skew or detail gouge, with better results.
If you become addicted like the majority of us have, you will quickly become a tool junkie ;^).
