DNA soaking question
chris rolke
>i have been doing the DNA soaking for a while
now having upgraded my lathe to a 1642 the 5 gallon bucket will be too small
what is everyone using for a larger container ?>?
need something sealable
thanks
Re: DNA soaking question
Don in Central Illinois
>I have heard of others on this forum, I think, that uses the larger plastic bins from Wal*Mart or one of the big box stores. Some of them will hold several quarts and sealable.
Steven Antonucci
a garbage bag
steve antonucci
>i put big things in a double garbage bag and tie it up around the object. I pour the DNA around the object and tie the top. When I am done soaking, I cut a small hole in the bag and drain into a 5G bucket.
Steve
Dale Cook
>I use a short and wide plastic garbage can. I put a garbage bag across the opening and then snap on the lid to slow evaporation. If part of the piece is still above the alcohol level I soak a paper shop towel and cover it, or rotate it every so often.
Barbara Gill, Remlik VA
>I have a large round container from Wal-Mart. There is a pile of shavings in the bottom. I put the piece in a large garbage bag and nestle it down in the shavings to reduce the amount of denatured alcohol needed to cover the bowl.
>I bought a set of stainless steel bowls from Costco or some such place. One of them is huge and the next one is nearly huge. So I rough the blank, see which one of the bowls it most nearly fits in and there you go. I put the whole thing in a big trash bag and tie it up to cut evaporation. If you shop around you might even find a set of SS or plastic bowls that have plastic snap on lids.
Ditto
Carole Valentine
>Mold the shavings to the piece and you use about half or less as much alcohol. I just pour it back in the can when I am finished and use it over and over until I figure it needs to be changed (very subjective!)
Amount of Alcohol easily calculated *LINK*
Charlie Anderson
>Dave Smith has a method to calculate the percentage of DNA in your solution on his blog.
Calculating Alcohol Percentage
Ric Taylor
Ric Taylor
>I have a short, wide (approx 7" x 17" x 22") tupperware-style plastic clothing storage box with a snap on lid that I use for items like platter blanks. For more compact shapes I have a cylinder shaped plastic cooler about 12" wide by 20" high, also with a snap on lid. For extra help controlling evaporation, I seal the lids with tape.
I soak my blanks for a lot longer than Dave Smith recommends, usually at least a week or longer. Sometimes that's just my preference, but usually it just takes me that long to get back into the garage.
Ric
Bob Elliott
>I put mine in an ice chest and filled it about half way up a large bowl standing on end on the rim with the end grain down, then rotated the bowl 180 degrees once a day so that the "straws" in the end grain continued to suck it up equally. Worked real well for me. Re-turned that bowl after two weeks of the rough turn.
Dick Hines
Dick Hines
>Go to one of the big box stores and look in the storage department. They will have what you need.
Re: Large Tupperware Cake container.
Allen Neighbors
jared
>I sawed off the bottom of a 30 gallon plastic barrel so it was a bout a foot high, filled it with shavings and pput the garbage bag full of alcohol in it. The only thing I do different is to use 3 or 4 bags, one inside the next, inside the next etc, then if the inside one gets a hole poked in it from a rough spot on the wood, sliver, etc. you dont lose the alcohol. I have left the alcohol in the bags for months with no problem. Jared
