kelton set screws
keith zimmerman, Normal IL
>I've lost a couple of the set screws for my kelton handle and need to replace them. Does anyone know where I can get replacements?
Thanks
keithz
kelton set screws
Thanks
keithz
Re: kelton set screws
Leppikallio
>I think (if I remember correctly) those were metric set screws, either 5mm or 6mm? Does 1/4" screw fit almost? If it does then it probably is 6mm thread...
If you can't find metric set screws closer I can send a letter to you. On this side of pond those are easy to get and cheap also.
Jorge Castaneda
>Keith,
I got replacements for mine at the local hardware store,
I just took in the handle and then tried screws until finding the righ one.
George Van
>Like Jorge, I got mine at Ace Hardware.
>me too. My local ace hardware has a good selection of set screws in both metric and english sizes
Dick Hines
>Check a good hardware store but don't try Lowe's or HD. Been there done that.They no got.
Re: Did you try the specialty hardware drawers?
Al Crandall
>I have had good luck finding what I needed at Lowe's in the drawers of specialty hardware. Two days ago I bought two 1/2x3" socket head cap screws from those drawers. I'm positive that I have bought metric screws from the metric drawers also, but I can't remember definate sizes. I know that the metric screws holding the shopmade chuck jaws on one of my Talon chucks came from the drawers at Lowe's. I don't shop HD.
Gordon Seto
>It is 8mm diameter x 8mm long. They are so easy to get lost on the unused end;; I bought several spares.
Gordon
Gordon Seto
>You can find this metric "Set Screw - Socket" at the HD and Lowes. I have purchased from both.
Gordon
Thanks everyone,
keith zimmerman, Normal, IL
>I'll stop tonight. I have all the sources mentioned available to me. I thought they would be readily available, but have never purchased any before.
keith
Dick Hines
>I have started putting a piece of tape over the unused end to keep the screws out of the chip pile.
Stuart Johnson
>Duh, this is a forehead slapper. You might want to send this simple but time saving tip to John.
