Questions RE: grain fillers
Mike Jones
>I was given some mohagany and have some pretty nice lidded boxes made. After several caots of Deft sanding sealer, I can see that I am up against a recurring problem when working with very open-grain wood.
I have heard of hand rubbing with pumice to fill grain...but wonder if you have some other suggestions???
Re: Questions RE: grain fillers
Re:Sawdust...
>Per the suggestion of Russ, I used some mahogany sawdust as my mahogany filler. I was doing an oil finish and it worked quite nicely.
Not To Crack Wise But
>Use a real grain filler. I use Crystalac clear filler for a "piano" finish on open-grained woods. Easy to use, and does a far better job than using finish or other "stuff." Becomes transparent under the finish. you can also tint it to contract with the wood (like liming wax) if you choose.
mm
Jim Miles-Charlotte, NC
>On most open grain woods, I put Linseed oil on it when I am at about 220 grit sanding it, then sand it with the oil on it, the slurry will fill grain, small cracks and imperfections, most finishs do fine over it, however by the time you use a couple more grits most of the oil is gone.
