Sorby Revolving Steb Centre -(for spindle turners)
>I finally picked up one of these with a 7/8" diameter tooth pattern and a #2 MT. They do make a difference. I've had a Sorby Steb Centre for my headstock side for a while and really liked it.
The live centre for the tailstock allows me to have a minimal longitudinal pressure along the axis of the spindle. This means less flex and chatter when turning the longer, thinner spindles (I hate having to use a steady rest). If you aren't turning spindles, I don't know how much use it would be.
Re: Sorby Revolving Steb Centre -(for spindle turners)
>JL the problem I have with the stebcenters is the spring in the center point. It applies so much pressure I get chatter from that. I use a standard live center in my tailstock. I quit using my stebcenter and went back to a 3/8" spur drive. I can tighten it up quite tight for roughing and then when I get the spindle thin I back off the tailstock until it squeals and then tighten it a tiny bit. This gives me the least amount of pressure needed to drive the spindle.
>Were you turning your small, thin stuff? I'm turning kiln dried maple and oak. I think the thinnest that I go is maybe 1/2" with a total length of maybe 25-30". I haven't noticed any chatter (yet).
>JL These are usually my mirror handles which are 10" long and vary from 3/8" to 3/4" along the length. I support the spindle with my fingers and that reduces the chatter considerably but I get quite a bit less when I back off the tailstock pressure
>I tried the Steb Centre for a while. It slipped while roughing, cutting a nice circle in the end of the piece, then the spring pressure was too heavy for the delicate thin turning. Like John, I now use a small spur drive and a point in the live center.
>The arm posts and stiles are 1/2" at the smallest diameter and the stretchers are 5/8" at the end. I've got Steb centres at both ends now and the chatter is nearly non existant. I've got the teeth of the centres just engaging in the wood.
I use the 1//2" steb center on all of my thin spindles and it works very well for me. The spring is indeed strong and will exert a lot of force, often enough to crack thin blanks especially of hard, brittle woods.
However, the method I use eliminates the problem. Before mounting, I use a hand gimlet to make a small hole centered in each end of the blank. This only takes about 5 seconds. The point is seated in the hole and the pressure is reduced, and has the further advantage of quicker mounting at the desired point.
Note that the spring can be removed and modified if desired for less pressure.
keith tompkins
>A neat trick for long, thin spindles, such as finials. I form a tenon on my stock, and glue it into a hole drilled in a waste block, held in a chuck. Minimal pressure is needed from the tailstock, and the piece never slips, while whip is reduced significantly.
Russ Fairfield
>Make a block as Keith describes, but cut a slit in one side so it will clamp down on the tenon as you tighted the chuck. Works the same, but the waste block can be reused.
Re: Sorby Revolving Steb Centre -(for spindle turn *LINK*
charlie belden
>Totally agree about the spring tension in the Stebb Center tail stock drive being way too high when it comes to fine spindle turning.
If you have a set of "pin jaws" and a scroll chuck I'm not sure why don't chuck the blank directly in the chuck jaws since they'll close down to a little under 1/2" diameter.
For longer thin spindles I just chuck up a square blank and support the other end with a live center - the one with a small pin and a ring. The small pin doesn't penetrate as deep as the longer, larger pin on the regular tail center and it's mainly the ring that holds the end of the blank - without splitting anything.
Once I've got the last inch or two pretty much done I point off the end from the tail center, remove the tailstock and turn the rest just held in the chuck jaws.
Once you've got things roughed round - and IF you use semi sharp tools - AND don't try hogging off a lot of wood in one pass - wobble and flexing aren't an issue.
Third photo on the page at the attached link shows what can fairly easily be done - in this case out of Santos mahogany, which, with its open grain is a little trickier to turn than say maple.
And if you want to turn REALLY thin stuff, as in 0.02" diameter, check out the third from the bottom photo on the next page - in poplar - done with on old bayonet saw blade - with a paper towel handle.
I know I posted this picture before, but take notice that I'm using a set of pin jaws to hold the stock. The longest finial I turned this way was 6"-7" in length.
The trick is to start and finish the tip then work your way back to the chuck.
For reference the skew is 1/4" round.
russ Fairfield
>Charlie,
Having the piece of wood acting as a "false jaw" keeps the tool from coming off the end of the wood into close proximity with a piece of steel that is spinning in excess of 2500 RPM. It didn't take very many contacts between tool and chuck to convince me that this might be a better way to hold a spindle by its tenon.
JohnKJordan in East TN
Another way with the same advantage is to turn a short morse taper on the end of the wood and press it into the headstock spindle as a jam chuck. Besides being very quick (once you learn to cut the taper!) it is low profile (no chuck to catch fingers) and minimum length. The latter was especially important when I set up on site and turn wands on a mini lathe - the lathe is just too short to hold the length I need any other way.
