Jacobs chuck
Jacobs chuck
Jacobs chuck
Lou
>I'm very new to turning, so forgive me if this is a silly question. I recently bought a simple jacobs chuck from a hardware store and want to use it on my mini Jet lathe.
How do I attach it to my lathe? What do I need?
I have studied the catalogs and I get confused. Do I really need to buy one from a turning catalog?
HELP!
Thanks
Re: Jacobs chuck
Re: Jacobs chuck
>Lou The problem is adapting the jacobs chuck to a #2 morse taper. Often you can buy and adaptor from places like MSC or Enco that will go from #2 morse taper to whatever your jacobs chuck has on the backside. Quite often that is either a jacobs taper of 1/2" x 13 screw thread. Actually it might be 1/2" fine thread which may be 20 tpi, i'm having a senior moment on that.
the reason most of us buy from the jacobs chuck from the wood dealers is that it's already been adapted to the morse taper and may be cheaper than buying the parts seperately and paying for shipping.
Bestwoodtools has an excellent deal on a keyless chuck with morse taper. This is a precision tool for a really good price.
Re: Jacobs chuck
Re: Jacobs chuck *LINK*
Clem Wixted, Jonesboro, AR
>Lou,
You are about half way there.
The Jacobs chuck needs to be fixed into the headstock (or tailstock) with a #2 Morse taper, You have a #2 Morse taper female in your headstosk spindle and tailstock spindle.
The chuck needs to be connected to the #2 Morse taper.
The connection is a male arbor that has a #2 Morse taper on one end and a "connection mechanism" on the other end. The "connection mechanism" has to match the inside of the Jacobs chuck.
Most of the simple Jacobs chucks I've seen at a hardware store have a threaded hole inside of the chuck, or a hole that a screw goes through to connect it to a tool, such as a drill.
You will probably need something a little stronger than a screw to hold the chuck to an arbor.
Many of the lathe chucks have a "socket" that the #2 Morse taper arbor mates to for a solid and strong connection, rather than a screw or threaded hole.
Below is a link to more information about Morse tapers than you may care to know :-)
HTH,
Clem
Morse Taper Information
Re: Jacobs chuck
Re: Jacobs chuck
>The others have gotten you on he right tract about the chuck. One thing to keep in mind is that those chucks are not really made for mounting wood. If you were going to mount the chuck on the headstock and then chuck a piece of wood such as a dowel and turn it or turn whatever you mounted on the dowel, be careful. The chuck slips into the shaft and will twist and lock in on the Morse taper, but not very securely. The vibration of the turning and sanding can loosen it and it may fly out while under power. If you intend to use it in that way you should get one that has a "draw bar" or piece of threaded rod that runs through the hollow shaft of the lathe and you can put a nut on the outboard end. Just has to be snug to keep the taper in the shaft of the lathe.
Re: Jacobs chuck
Re: Jacobs chuck
Lou
>I want to make tool handles, so the main thing I would be using the jacobs chuck for would be a drill bit.
Thanks for your help.
Re: Jacobs chuck
Re: Jacobs chuck
>Lou It will work fine for drilling without the drawbar. If you try to turn something using the jacobs chuck you definitely need a drawbar but this chuck also crushes wood and the piece will fly out so it's not very good for that anyway. Craft Supplies sells a jacobs chuck with the jaws ground differently. They sell this to turn bottle stoppers and it will hold a 3/8" dowel very securely.
Re: Jacobs chuck
Re: Jacobs chuck
keith zimmerman, Normal, IL
>Lou, my first Jacob's chuck was one from Menard's with the 1/2x20 threaded hole in the back. My old Sears lathe had a solid tailstock spindle without a Morse taper so it was perfect for me. I obtained a live center from someone that had a Morse taper that actually unthreaded from the center. (I needed the live center portion)
When I moved to my Jet mini with a Morse taper, I screwed that Morse taper into the back of the Jacobs chuck. I don't trust the connection all that much and only use it for drilling, nothing else. I bought another Jacob's chuck specially designed for a lathe for all the other processes.
I would get a Jacob's chuck with a Morse taper because it can do more that just hold a drill.
keithz
Re: Jacobs chuck
Re: Jacobs chuck
Carol - now in NC Nebraska
>I had a new drill chuck with a JT33 taper (stamped right on the chuck). I got an adapter from Woodsmith (I was in Des Moines and stopped to just mosey around the new store). It had the JT33 on one end and MT2 on the other. Less than $10. These kinds of adapters are available at Enco, McMaster Carr, and probably tons of other places as well.
So now I have a drill chuck ready for exclusive use on the lathe.
Re: Jacobs chuck
1/2-20 or 3/8-24 thread
Ken Grunke from SW WI
>Lou, if you bought a Jacobs chuck from the hardware store with a female thread, 1/2-20 or 3/8-24 are the standard threads on portable drills so you need to find a morse taper shank with a male threaded end for your chuck. If you have a Sears store nearby, go to the lathe accessories section and you may hit pay dirt. Otherwise such a shank may be found at Enco or Wholesale Tool, they both have websites whose URL's escape me at the moment but accept online credit card orders no problem.
Re: Jacobs chuck
Re: 1/2-20 or 3/8-24 thread
>Sears does sell a #2 morse taper with a 1/2" thread but they usually don't even know what your talking about. Dig out the catalog and look under that lathe accessories and you should be able to find it.
