screw lid boxes
screw lid boxes
screw lid boxes
>You haven't seen too much from me lately. I've been filling orders. I've made a dozen mirrors, a dozen wine stoppers, a wine stopper display and a square lidded box (not turned). I finally had time to play with my Baxter threading machine. Here are 2 boxes. One is box elder that is bleached with a lacquer finish. The other is a hickory box that has fluted sides. I bleached a section of it and then air brushed black onto the rest. The inside was left natural. It also has a lacquer finish.
They are about 6" tall and 3" around. I made them accurately enough that you can swap the lids. The threader I have is 16tpi. You can get other sizes from Vic but since this is the biggest box I plan to make I think 16 is about right. Most boxes will be smaller.
Re: screw lid boxes
Re: screw lid boxes
Re: screw lid boxes
Re: screw lid boxes
Barry Elder
>Those are really very nice, John!!
Re: screw lid boxes
Re: screw lid boxes
Carole Valentine
>This one is my favorite, John. Was there much of a learning curve with the Baxter? Are the instructions clear? How many did you do prior to these two? ;)
Re: screw lid boxes
Re: screw lid boxes
>Carol These are the first two. sort of. I made the bottom of one first with female threads. Then I made the top and also put female threads on it. Ooops. Then I turned a correct top.
The learning curve is fairly easy as long as you can read a dial caliper accurately. For this size thread (16tpi) you size the opening and put the machine on the lathe. You adjust it until the wood just touches the cutter. Then you move it out .035". The markings are on the dial. Then you turn the other part to the thread dimension + .035. put it on the machine and go through the same setup but the cutter in .035. That sounded complicated but if you follow the handout that comes with the machine it's really straight forward.
Re: screw lid boxes
Mike Stafford
Really sweet!!!
Mike Stafford
>John, these look great. I hope to get into threaded boxes one of these days but alas there is so much to do and so little time to do it.
Re: screw lid boxes
Re: screw lid boxes
Allen Neighbors
>John, I hope to be able to make some threaded boxes, also, but I'm going to try it by hand, since I have nothing but time. I know there's a heck of a learning curve with the hand chasers. I bought a set of 16tpi to start with. I found out it's a lot easier to make 16 grooves per inch than 16 threads per inch. :)
I did finally make some decent male threads today, just practicing. Walnut and Ash (not good for threading), Ebony (threads beautifully), and Lignum Vitae which also threads beautifully.
Beautiful boxes, John. I like the BE the best!
Re: screw lid boxes
Re: screw lid boxes
Jim Terry
>John, I like them both, the BE is very nice and I like the fluting on the other. I have tried some dying with an airbrush. After watching Jacques this weekend gave me some more ideas.
Jim
Re: screw lid boxes
LOL!
Carole Valentine
>I thought I was the only one who would do something like that! At least you were not working with a piece that you wanted the grain to line up.
I would think Box Elder would not be a very good wood for threading because it is sort of soft. Apparently you got it to work OK.
Re: screw lid boxes
Re: screw lid boxes
Paul Waddle
>John,excellent work. Which threads do you cut first,top or bottom? I beleve the conventional approach is to first cut the male threads,but it would seem easier to make the male fit the female threads?? And does it really matter if the female threads are on(in) the bottom and the male is on the top? Is this for protection of the threads? Sorry for the insatiable questions,but these facinate me. You have indeed, an excellent talent-and these are just your FIRST two too! pw
Re: screw lid boxes
Re: LOL!
>Carol I'm still working on threading soft woods. I did have a few chipped places in the threads. I made a cut and then soaked them in CA and made another cut. It worked good on the Hickory not as good on the Box Elder. I'm going to try a lacquer soaking on some test pieces.
Re: screw lid boxes
Re: screw lid boxes
>Allen I'm going to learn to thread chase by hand. I purchased some chasers. My problem is I rarely have wood hard enough to chase by hand which is why I bought the Baxter threader.
Re: screw lid boxes
Re: screw lid boxes
>Paul I'm brand new to this so I can't really answer your questions. It doesn't seem to matter which you turn first except that it's easier to shorten the female thread for grain matching than the male thread. When you trim the shoulder of the male thread you have really be careful not to damage the thread. With the female thread you simply remove a little at the top.
This is really going to be fun.
Re: screw lid boxes
Re: screw lid boxes
paul waddle
>I guess i will find out John,the Bonnie Klein tape I have does the female thread first and then the male. She takes a little off the male shoulder so that grain almost lines up. She indicates this is the preferred method as it will close more as lid is turned. My problem is I try to over analyize,guess I should just pitch in and turn a couple of boxes and see what works for me. Those snap fit lids are beginning to look really good now.ha ha pw
Re: screw lid boxes
Re: I understand what you
Allen Neighbors
>mean, John. I bought some 16tpi chasers, which was what everyone I talked to recommended, and I already wish I had gotten the 10? tpi instead. They told me the larger chasers were better with softer wood, and that the threads were sort of rounded over. I've not tried these 16s on Mesquite or Bois d'Arc yet, but I know the Bois d'Arc will thread nicely... just wondering about the mesquite.
(The last mesquite I got was pithy and ring checked pretty bad.)
Re: screw lid boxes
Re: screw lid boxes
tek-Brunswick, Ohio
>We just had a demo by Mark St.Leger. One of the subjects was hand chased threads. Mark says that the finer threads are easier for beginners to learn. He suggests learning with the 20 TPI chasers and then going to the coarser chasers. I brought in my 16 TPI chasers that I tried a few times, but am not very good with. He touched them up for me on the grinder. My chasers had both started out with a 1/2 tooth on the end. He ground them back so they started with a full tooth. He also put a hollow grind on the top of the teeth. He didn't grind off much just enough to get the whole top of each tooth and just past that onto the solid part. He uses paste wax as a lubricant when he cuts maple and other domestic woods. He puts it on with a toothbrush. He doesn't use the wax on oily woods like Blackwood. Blackwood and boxwood are his favorite woods to thread. He says to practice on maple using the wax. He cuts the female threads first and fits the male threads to that. I haven't had the chance to try out his tips yet. I hope some of this helps.
Tom
Re: screw lid boxes
which tools?
JohnKJordan in East TN
>I read a magazine review once comparing three different brands of thread chasers and one had particular advantages. However, I can't locate the article at the moment.
Re: screw lid boxes
Re: screw lid boxes
Allen Neighbors
>Thanks, Tom, I appreciate the information. Everyone that offered tips last weekend advised me to �not� start with the 20tpi because they said it was harder to begin with the finer threads. Just goes to show that we all don�t think alike, huh?
I like the idea of the paste wax as a cutting lubricant. I�ve been helping with Fire Prevention week the last two mornings, so I haven�t turned very much since I�ve been back. Just a little practice threading male threads, and making spheres.
Thanks again for posting.
Allen
Re: screw lid boxes
Re: which tools?
Allen Neighbors
>John, I bought the chasers that Craft Supplies was selling at SWAT. They had a name engraved on the blades that I�d never heard of, but someone told me they were made by Crown� I don�t know. I eased the bottom corners and sharpened them, and they cut very well. I didn�t by the Sorby�s because they were quite a bit more expensive, and came with a measuring tool that I didn�t want.
Re: screw lid boxes
Re: LOL!
Jorge Castaneda
>John,
If you can make threads in box elder, so soft, you will have no trouble threading in hard dense woods.
I like the flute one best.
Thanks for showing
Jorge
