Bleached and Blasted 5250
Bruce Forrest
>This is an ash hollow form which has been bleached and sandblasted. About 10 1/2 inches tall. All comments welcome.
Re: Bleached and Blasted 5250
Steven Antonucci
How do you sand blast them?
steve antonucci
>I like the teardrops much much better. This seems kind of "plain" compared to your other work. Just my first impression when I saw it...
A question:
Do you have your own rig or do you go somewhere and rent by the hour/piece? I haven't tried it yet, because I hear that breathing the dust is REALLY BAD for you (vs. all the other things I do in the shop that are only a little bit bad...)
I've debated getting a little canister for the compressor, but I don't know anything about it...
Steve
Re: How do you sand blast them?
Barry Elder
>Unique wood art! Keep some gloves around for handling. Good counterpoint to your other work I've seen here.
Bruce Forrest
>It quickly became apparent that if it was to be any more than a summertime activity that I would need some equipment. I bought a floor model sandblast cabinet(around $200 at Princess Auto) and put it together. I already had a nominal 4hp 14 gallon compressor, and it is the absolute minimum I'd recommend. Even with it, it's blast for a minute or so and then wait for the compressor to catch up. Not a problem if you don't do it a lot, but if you do, then you need a behemoth of a compressor (60-80 gallon) type which will run you in the neighbourhood of $1K. The cabinet keeps my lungs intact and if I noticed any leakage, I could always put on the Triton that I use for sanding at the lathe.
The turning is kind of plain, but I like to think of it as skeletal.
Carole Valentine
>Nice, Bruce. I wonder what this would look like dyed black with liming wax. Ash has such a distinctive grain. George Van sent me some roughed out ash bowls and I am keeping them for the day that I have a sandblaster!
Darrell Feltmate
>Very nice. Ash is a versatile wood for treatment after turning. I have a couple of pieces that I have dyed with mahogany dye after turning and they look like rosewood.
What blasting medium do you use?
James McClure
Or is it media?
James McClure
Actually, the particles are kinda small.
Bruce Forrest
>Seriously, right now I'm using something called Ecoglass, made from recycled glass that I got on sale at Princess Auto.
Carole:
Bruce Forrest
>Hi Carole, I posted a beaded ash bowl here a while ago. Just search the number 5245 and it'll come up. Not sandblasted, but an ash bowl dyed yellow with black wax. Reverse the color scheme and you'll get a good idea of what the white wax on black looks like on a bowl.
Bruce
Re: Carole- you can achieve a very.....
Jamie Donaldson
>...similar effect with a round wire brush (with thin wire)chucked in a drill. I have used several with brass and even nylon over the years, and don't have all the equipment and safety demands of sand blasting.
