Sanding green wood
Sanding green wood
Sanding green wood
Dave Winters
>Any tips? My paper loads up awfully quick power sanding. I clean often with the crepe rubber block.
As always, thanks!
Dave
Re: Sanding green wood
tm
>In Del Stubbs' video he uses wet / dry sandpapers with LOTS of water,
dipping frequently in a small container.
Be sure to dry the ways etc. when finished.
What wood, and which sander?
Keith Newton
>Most wood is only half as dense / hard when it is green, so is easier to cut / sand. Maybe you are using the wrong products.
What are you trying to do?
Leppikallio
>Perhaps dry surface just a little with heatgun?
Brian Hahn in SW Wisconsin
>I've found that hand sanding with wet/dry sandpaper with water works the best for wet wood. I put a plastic dishpan on the bed under the turning to catch the water and use a squirt bottle (old dish washing soap bottle) to both lubricate the sandpaper and to wash off the wet sawdust. Did I mention that I do this with the lathe off?
Re: Sanding green wood *LINK*
Darrell Feltmate
>Dave
I like to sand hollow forms turned green and then let them warp as they dry. Also, I like to sand on the lathe with it running and use a power sander. Two things can really help. One is to dry the surface with a heat gun before sanding. Only the surface will dry and the piece will still try to throw water but it helps. The other is a small brass brush (I got mine from the dollar store). Instead of the crepe rubber use a brush to remove the fill on the paper. It is really easy to harden the stuff on the paper but a couple of swipes with the brush and you are back in business. Do NOT use a steel brush. It can leave particles that will react with wood or finish or some of that water in the piece.
There is some stuff on sanding including a video or two on my site under "techniques".
Around the Woods: Sanding
robo hippy
>I guess it will depend on what you are sanding. I do a lot of green turned bowls that I let dry and warp, then sand and finish. I love the warped shapes. I tried the heat gun, and it does work, but takes extra time, and you do run the risk of heat checks. You can spin the piece at a higher speed and throw off the water. This makes a mess, and is time consuming. I have found it easier to let them dry a bit first, even for a day or 3 or 4. They will reach equilibrium, and be done moving in about 10 days. You can sand them earlier than that, but I usually have a surplus of bowls to sand so most dry longer than that. I do use the LDD soak (1/2 liquid dishwashing detergent, amber color, and half water, soak for 24 hours, rinse then dry), and feel that it helps sanding a lot. One guy sands them straight out of the soap. The glycerine in the soap acts like a lubricant for the sanding discs. The wet sanding method is messy, especially if you don't have variable speed, and most of the wet/dry sandpaper is in the higher grits, 220 and up, so you need to do a very good job of turning so you can start with 220. If you are power sanding, you need the eraser sticks.
robo hippy
Doug Turner
>I attended a demo from Vic Wood years ago and he poured alcohol on the green wood and lit it with a match. This dried the surface enough to sand. All shavings and flammable material were removed before hand.
Dave Winters
>Thanks for all the tips. I am turning pimento wood, which is the most difficult wood to dry I have ever worked with. I've tried DNA soaking, green wood sealer, and boiling. With all these the rough turned blanks warp and check so much there's nothing left to turn when dry. So my new strategy is to turn thin and sand and just let 'em go off.
But as I said, when power sanding my paper loads up, bad.
I'll try to post some pics soon.
Keep the tips coming...
Thanks, Dave
