Drop In Power-Jet 1236 lathe-Belt Problem?
>Good Afternoon Friends,
My best friend was using my Jet 1236 this morning and we noticed it lost power when he put the bowl blank under only moderate load. RPMs would recover immediately with reduced tool pressure. I hadn't experienced this problem before, so I tried it and experienced the same problem. I removed the belt cover and looked at the pulleys. They expand/contract to change diameter, and seemed to perform fine as I went through the speed ranges. However, when we put the lathe tool to the stock, the belt seemed to arc outward as the stock bogged down under tool load. The headstock and drive spin freely and the motor seems okay. I am thinking maybe I need to buy a replacement belt. Have others experienced a similar problem? Any ideas? Thanks.
George
Re: Drop In Power-Jet 1236 lathe-Belt Problem?
Its slip is showing
Jack Savona
>Sounds like a belt that's slipping. Try roughing up the sides of the belt with coarse sandpaper. If that doesn't work, I'd suggest you go to an auto parts store and get a "machine motor" belt.
Re: Its slip is showing
Dennis Taylor
>Don't post often, but had the same problem, will change speeds, and the loop in the belt is normal, mine did the same, but the belt is slipping, try the sandpaper, I just replaced the belt, but the sandpaper might work, maybe a strip at a slow rpm and rough up the belt material....good luck...don't think the problem is anymore serious though....dennis
Barry Elder
>I had the same problem a while back and a fellow turner who remachined his HF lathe came over and we took the Reeves drive off the motor and found that the keyway and the pulley pieces were not lined up. Not sure how to explain. Anyway, he showed me what needed to be done and when we finished, it ran like new. The point being, even though the belt was slipping, putting a new belt on only worked for a few hours and then I started losing power again. Then he came over and we fixed it. If you take it apart, be gentle with the pulley halves, as they break when hammered on!
Pete in Holland
>A new belt will cost around $5. Grab 2 for when the new belt goes kaput on a Sunday afternoon.
Re: 1236 Problem
>Good Morning, George,
I replaced the belt on my 1236 with a Fenner drive (link-belt). Have to be careful about the direction of rotation, but it ran fine. The rest of your problem appears to be in your reeves pullies. I had mine apart once to clean and dry-lube the parts, and it seemed to help, although I didn't have as drastic a degradation as you describe.
mm
Reeves lubrication question
Ken Grunke from SW WI
>What is the best lube for these reeves drives? And the proper way to apply it?
On a 1236, I have been using a spray lube (NOT WD-40, but an actual oil) and I probably get a little on the belt. The lazy way but it always helps.
Is a light grease better?
Thanks for any tips, Mark, or anyone.
Re: Reeves lubrication question
>Ken, I used only the graphite spray and only on the reeves shafts so that the sheaves would move smoothly on the speed changes. Got to keep it off the belt or the inside surface of the pulleys. Oil or grease will get dusty (wood and abrasive) and cause wear on those surfaces. Get one that uses the small straw on the spray head or change it with a WD40 spray head and straw (which you clean first).
mm
