Yew Pine ( podocarpus macrophyllus)
Marttin Harris
>I am very new to turning and not at all sure about what type of wood to scavenge. A neighbor is about to harvest two podocarpus macrophyllus (yew pine). Is this worth saving for turning projects? If so, what advice would you give me on preserving and turning it?
Thanks
Martin Harris
Re: Yew Pine ( podocarpus macrophyllus)
Jimiles-Charlotte, NC
>Don't know Yew Pine, where do you live?
Generally speaking, Pines are messy, the sap is resinous, and makes a mess of lathe & tools, and gums up sandpaper when wet, If it is next door, you don't ready acces to other wood, you might try a small piece & see how you like it. Only way to learn it to make shavings!
tm
>I was curious because its used frequently in landscape plantings
in my area.
Podocarpus elatus:
European use. The wood has a very fine, even texture and a straight grain with inconspicuous growth rings. It has been used for table tops, furniture, packing cases, kitchen utensils, musical instruments (piano keys and violin bellies) and wood turning.
In S. Africa & Australia Podocarpus is sometimes used.
There are probably better choices but if its free why not give it a try?
tm
Bill Hale / The Wood Spinner
>Podocarpus is not a pine. It should turn nice and clean.
Good turning and be safe
Bill in Casa Grande, AZ.
Barry Elder
>Have turned a few pieces of weeping podocarpus from a botanical garden after a hurricane. Turns easily while green, spalts and rots easily. Needs sharp tools.
Martin Harris
Martin Harris
>Thanks for all the feedback.
I live in Sacramento, CA where this tree is used for landscaping. It is also known as Kusamaki.
The trees to be cut are about 20' tall with a trunk from 13" to 7" in diameter and dead straight. I found one reference to its use in turning at http://www.woodworkforums.ubeaut.com.au/showthread.php?t=45586. It is also used to make long bows!
Martin
