>The Wed. chat talked a lot about epoxy but nothing was said about clarity. I had heard that West was the best ??
I just bought a Qt of Resin and two Pts of hardner, one fast and one slow.
My primary use will be structural on larger hollow forms with large voids. Eg. I am now working on a 23" x 9" oak burl and one side wants to release. I cut a bow tie and am going to epoxy it in.
>I use System 3 epoxy. Their standard epoxy has an amber cast from the hardener that is visible with 1/4" thick pieces. The clarity is very good. Their Clear Coat is colorless and water clear. I haven't used their Mirror Coat, but I expect it would also be colorless and clear.
I've never used or seen System West epoxy so I can't compare them.
>I have used West System for years. I usually use a filler, coffee grounds plus a blackener. I don't think I have ever used it without pigment or filler so I don't know how clear it is.
>Bill, It will be an amber color when cured and not very clear. Also, remeber that epoxy is sensitive to UV degradation, so needs to be covered with something or to have a non-transparent coloring aga�nt mixed in with the resin. Wood dust or graphite are a couple of choices.
Just curious, I built a solvent recovery plant in Casa Grande back in the 80's for what I now believe is a Donnelly printing plant. The special thing about this is a very tall hot water tank used to recover energy to make steam from - a system I have a now expired patant on.
>System 3 mirror coat is very clear but it becomes very viscous when it's heating up to the hardening process. It can actually penetrate the endgrain. Most of the time it works perfectly filling gaps, but sometimes it will actually wick into the wood and not harden which of course ruins the work. I started sealing the endgrain with shellac and it seems to stop the problem.
I don't know how the clarity stands up to many years of exposure to UV. Many epoxies yellow with time. I have pieces that have been exposed only to indoor lighting and they are fine after as long as 5 years. That's about as far back as I go with this stuff.
Yes the factory is still here but Donley has been gon for several years. I thiunk they moved South East where labor is cheaper. The buildings are still in use but I have know idea who is in there now.
>Could it be that you are talking about using epoxy resin? or two part epoxy glue? The glue is definitely colored somewhat but has the strength, but the epoxy resin I would experiment with before using it on a finished piece. It may or may not have the strength you are looking for. When filling voids, I used the epoxy glue with either a contrasting color or filler, or do some extra sanding and mix the dust with it. Can be very confusing. I use epoxy resin for coating and filling incidental holes, dings, worm tunnels, etc.
Now I am even more confused. I bought the pumps to be sure I got a correct mix. I primed the pumps to be sure they would dispense a full amount of epoxy and hardner. It os now on the piece and seems not to be setting up. I used the slow hardner but it has been about 45 min and it still wipes off on to my finger. It feels a little oily, no tack.
>I use West System epoxy. The fast hardener is amber. The slow hardener is clear (not water clear but pretty close). The extra slow hardener is very amber. The "Special Coatings" hardener is the most amber.
I tend to use the slow hardener the most. I will often use filler and colorants. I want a predictable color so I use the hardener which the least impact on the color.
The procedure is:
Wet the joint. This means to apply mixed epoxy to both sides of the joint.
Apply, colored and filled epoxy to the joint.
Clamp the joint. You really just want to hold the pieces in place which the epoxy cooks. It is easy to apply to much clamping presure and force all the epoxy out of the joint.
When gluing endgrain I will often need to "wet" the joint several times. If the joint doesn't look wet when you are ready to clamp the joint you need to apply more epoxy.
If you can apply heat to the last 20% of the cure time you will improve the strength of the glue joint. Not a lot of heat, 120 to 140 degrees F for the last half hour
Warming the wood before "wetting" will cause deeper penetration of the epoxy.
>When the clear coat hardens it's just like epoxy. It's solid and very clear. I don't know how it is as structural because I haven't tried it that way. What I meant by viscous is that it is a thermally setting epoxy. When it is curing it produces a fair amount of heat and this makes it thin and runny. It's hard to use to fill gaps because you have to block off the hole with something it won't leak around.
>I found I had the same results with warm wood, both when first applying the epoxy and just before full cure, but I'll admit that I stumbled upon them by accident. I don't think I fully understood it until I read your post
