One other skew question...
Rob Hix - King George, VA
>When you grind your skews, do you leave them straight, or do you grind a radius on them? Tell me why either way, if you know.
Thanks again,
Rob Hix
Thanks again,
Rob Hix
Re: One other skew question...
JohnKJordan in East TN
>I like them straight. I find the control suits me and straight is easier to sharpen on the Tormek. Some people prefer a curved edge which is supposed to be more forgiving, but I haven't had problems with catches.
BTW, I use a fine diamond hone to renew a razor-sharp edge many times between sharpenings. This is quick and easy if the edge is concave (hollow ground).
>I agree with John I don't see any advantage to the curved edge and the straight edge is easier to sharpen using jigs on the grinder. I also use diamond hones to sharpen after the initial grind. I will sharpen many times with the diamond hones before I have to go back to the grinder.
Doug Thompson near Cleveland
>John, did you ever get that skew sharpened? I was thinking of it last night when I was roughing a few.
The first production 3/4 V shape bowl gouges were picked up today and I get to try one out tonight... I feel like a kid in a candy store.
This is a long day at work... only 1 hour to go.
Ric Taylor
>Rob,
I think you will find that is just a matter of personal preference, with no definite advantage either way. It's usually a case of what you grew up with.
Ric
Carole Valentine
>Flat and straight. I find it easier to use and maintain, especially when I hone it on a leather. I have an oval radiused skew somewhere in my shop and I don't care if I never come across it again!
>Doug I haven't yet but that is something on the agenda for today if I can fit it in. I'm excited about trying it out.
Ron in Drums PA
>I started out with a straight grind. Then one day I decided to try a radius curve on one. It took a while to get the hang of sharpening it. But once I did I really liked it. Eventually I started to put a radius on all my skews.
Last week, I decided to resharpen one of my 1/2" skews to a flat grind. I needed to use it as a scraper and I felt a flat grind would be better suited to the job.
I'm just starting to think it's nice having both types in your arsenal.
keith zimmerman, Normal IL
>straight, because that is what I learned with and am comfortable with.
keithz
