Dust free enviroment container (home made cheap)
Charles Beland
>If you haven't ever seen my shop It's minuscule. It's about 8' x 8' I have to go outside to change my mind. Whenever I turned something I had to wait until the next day so that the dust would settle so I didn't get anything on the finish. It would take me days to do one piece. While I was doing my Route I saw 2 stands to hold folding tv tables I figured I would use them to make some depth gauges for bowls.
I made a bowl & put the finish on & used one side of the stand on a table & draped linen napkins over to keep the dust down It didn't work. Well Pat (wife)
bought a new comforter for our bed & after I looked at the empty plastic container that it came in I had my first wood working Epiphany. So I went to my local Borg & got some 3/4" PVC & elbows & 1/4" Hardboard. this is what I came up with. Total cost was $31
All pics are thumbnails click to get the full size pic.
My finishing area is the table right next to the water heater.
[URL=http://i26.photobucket.com/albums/c117/xxxrecon/shop%20photos/2c9b9b7c.jpg][IMG]http://i26.photobucket.com/albums/c117/xxxrecon/shop%20photos/th_2c9b9b7c.jpg[/IMG][/URL]
Plastic zippered comforter bag.
[URL=http://i26.photobucket.com/albums/c117/xxxrecon/dustfree1.jpg][IMG]http://i26.photobucket.com/albums/c117/xxxrecon/th_dustfree1.jpg[/IMG][/URL]
So this is what I came back with from the Borgs. some 3/4'' PVC & some 3 way elbows & 1/4'' Hardboard.
[URL=http://i26.photobucket.com/albums/c117/xxxrecon/dustfree2.jpg][IMG]http://i26.photobucket.com/albums/c117/xxxrecon/th_dustfree2.jpg[/IMG][/URL]
I sized the frame to the bag & cut the side pieces 6'' & the length pieces at 18'' then assembled the frame.
[URL=http://i26.photobucket.com/albums/c117/xxxrecon/dustfree3.jpg][IMG]http://i26.photobucket.com/albums/c117/xxxrecon/th_dustfree3.jpg[/IMG][/URL]
Then I cut the 1/4'' hardboard to fit inside for extra strength & so my turnings have a stable base to sit on. I cut the corners in a half circle so the hardboard can't come out.
[URL=http://i26.photobucket.com/albums/c117/xxxrecon/dustfree4.jpg][IMG]http://i26.photobucket.com/albums/c117/xxxrecon/th_dustfree4.jpg[/IMG][/URL]
installed it inside the comforter bag
[URL=http://i26.photobucket.com/albums/c117/xxxrecon/dustfree5.jpg][IMG]http://i26.photobucket.com/albums/c117/xxxrecon/th_dustfree5.jpg[/IMG][/URL]
Completed dust free environment container in it's home now I can put the finish on whatever I just did zip the bag closed & I can do more turning or sanding & not worry about getting anything on the finish.
[URL=http://i26.photobucket.com/albums/c117/xxxrecon/dustfree6.jpg][IMG]http://i26.photobucket.com/albums/c117/xxxrecon/th_dustfree6.jpg[/IMG][/URL]
Re: Dust free enviroment container (home made cheap)
Carole Valentine
>I think in order for the pic to show, you have to use this code.
where the asterisks are the path to the picture and the file name. Been a long time since I have done it but I'll try it on your first pic and see if it works.
Nope. Forget that. LOL
Carole Valentine
>Have to look at the FAQs. Obviously I don't remember how to do it either.
eaglesc
>hope you don't mind.I was curious, I like home made.
Since I had to look them up anyway.
Original Post:
"If you haven't ever seen my shop It's minuscule. It's about 8' x 8' I have to go outside to change my mind. Whenever I turned something I had to wait until the next day so that the dust would settle so I didn't get anything on the finish. It would take me days to do one piece. While I was doing my Route I saw 2 stands to hold folding tv tables I figured I would use them to make some depth gauges for bowls.
Completed dust free environment container in it's home now I can put the finish on whatever I just did zip the bag closed & I can do more turning or sanding & not worry about getting anything on the finish. "
Is this what you are trying to do Chuck?
Ron in Drums PA
>(click on image for larger view)
Re:The problem created by this....
Jamie Donaldson
>....solution is now the volatile propellants/solvents can't evaporate well in the sealed chamber.
Peter Hyde
>I agree with Jamie on this. You are in for some very long drying times. I have a very dusty shop and tend to do finishing outside whenever possible. An alternative is to use an oil finish and use 0000 steel wool and oil between coats and then buff. I also spray lacquer in a dusty environment and usually sand between every coat and finish with 0000 and wax. I am not looking for a deep high gloss finish so the dust really doesn't bother me. As far as chips and shavings go, use shower curtains around the lathe to contain them.
>I have to agree with Peter. I stand in my doorway and spray lacquer. If it's raining I put a fan at my back to keep the excess spray outside. I have a cheap gun and I haven't found the optimum viscosity and pressure so my finish is rarely perfectly smooth. It easily sands flat with 600 grit or 4/0 wool. Most of the time it's good enough to just buff with the beal. I don't need a glass like finish on most of my work. A glossy finish is fine.
In my old shop I simply put a piece of cardboard on stands over the top of pieces. I think most of the dust comes from above.
I also use Minwax wipe on poly when it's simply too cold or too wet to spray lacquer. It takes longer to put on 3 or 4 coats but looks really good. The longer time is simply drying time not application time. It dries pretty much dust free and is easily buffed out.
