The painting isn't that difficult.
Brian Hahn in SW Wisconsin
>It just takes time, patience and top quality materials.
1. Seal the wood to prevent bleeding. I used 2-3 coats of a 1# cut of blonde de-wax shellac.
2. Apply a medium viscosity artist acrylic with a quality water color brush. I used Liquitex Soft Body (formerly Medium Viscosity) acrylics. Golden Fluid acrylics are equivalent. The water color brushes were a sable/synthetic blend, but next time I'll spring for pure sable brushes ($$$). The colors go on smooth and the water color brushes are soft enough that brush marks are minimal.
3. Hand-sand the turning to remove the over-painting and then hand-sand through the grits.
4. Seal with another thin coat of de-waxed shellac, then top-coat with the final finish.
For the solid bands, I only painted the outer grooves before sanding, then went back and filled in the bands.
The black gesso on cherry was a little more challenging. I didn't like the shiny surface from the lacquer, so I sanded the bands clean and reapplied the gesso.
