>I'm brand new here and haven't had a lot of turning experience, but here goes. I have a Jet Mini lathe (10 in face) and I want to turn some plates for some woodburning friends. What is the best way to chuck the blank, etc. ? Thanks.
I use a glue block in a faceplate, that way I can work both faces and then reverse chuck it with the tail stock support, do the foot area, or just a dimple and leave a little nib of wood around the tailstock and clean that off the lathe with a shap knife or a carving tool and sand paper.
>Jim I do plates in one of two ways. I drill a 2" shallow hole in the face and expand a chuck into the opening. Then I turn the bottom and also turn a depression for the chuck. I turn it around and turn the face. Although this works and is quite fast it's hard to control the shape of the face because you are turning the back first.
The other method I use is to drill a 2" hole in the bottom. Then turn the face. Then I use a piece of wood with foam as a drive and turn the plate around and turn the bottom. I use the tailstock to push the plate against the foam. I use a cup center in the tailstock.
Those are the old ways. Today I use a vacuum chuck and simply put the wood in place and turn the vacuum on. Then I will turn it either top first or bottom first depending on the necessity of that project. When done, I'll reverse the plate on the vacuum chuck and turn the other side. It's very quick.
>Thanks Jorge and John for your replies. I'm not sure which method will work best for me , but I think I'll study them first then give them a try. Thanks, again; much apprecieted.
