A "Distinctive" tool handle
Brian Hahn in SW Wisconsin
>The challenge this month was to turn a tool handle (basic spindle turning). The only requirement was that it had to be functional. I made a brace of my standard handles, then made this one for fun.
This handle is for those really "hot" turnings. The handle is air cooled with through holes from two directions, including several holes to air cool the tang. It is hickory, 1-1/2" x 12-1/2" with a copper pipe ferrule. The handle was distressed with a skew, a hand saw and a drill, painted with black gesso and acrylic paints, and then sanded clean and sealed with a 1# cut of shellac.
Comments welcome.
Re: A "Distinctive" tool handle
My normal tool handle
>Here is one of my standard tool handles for comparison. Hickory, 1-3/4" x 17", copper pipe ferrule, burned with wires, six flats, and a single coat of finish. The flats improve my grip and keep the tool from rolling off onto the floor. All of my tools have this type of handle; the length varies depending on the tool.
Comments welcome.
Steven Antonucci
That's pretty "cool"
steve antonucci
>I like the treatment. I'll bet that it won't be hard to spot in the rack...
Steve
Keith Tompkins
keith tompkins
>Brian, this would make a wonderful decoration for a bowl or hollow form!!!!!
JohnKJordan in East TN
>Cool! :) Next thing is to mount a battery-operated fan in the handle to move air through the holes.
>I was thinking Dry ice and a fan. Possibly with copper inlay to aid in radiating the heat away from the tool steel.
>Keith,
This was my "getting my feet wet" piece. I've got a number of ideas along this line that I'd like to explore.
>Darn, I didn't think of that! I was hoping that convection would be adequate.
But now that you've mentioned forced cooling, how about a compressed air fitting on the end of the handle. It also would help keep my palms dry during those really intense moments.
>Brian I'm thinking replaceable CO2 cartridges in the handle. Then when that moment of panic sets in you could hit the button and instantly cool everything off. Of course you might also freeze your hands to the tool. Some fine tuning will be necessary of course. It would blow out the holes and create quite a spectacle to the crowd.
That's definitely a good one!
