convex grind bowl gouge
>I would love to try a convex grind on a bowl gouge. How would I grind it. It's easy to grind a convex grind on a skew but I'm not sure I know how to do it on a complex grind like a bowl gouge. Any suggestions. I'm able to get a really nice finish on a bowl enterior but I'm always looking for something better.
Re: convex grind bowl gouge
James McClure
>Are you talking about a grind like the one JoHannes Michelsen uses? My club brought in Don Derry for a demo a couple of years ago and he uses that type of grind. I'm not exactly sure how he sharpens it, but I do remember that he sharpened it freehand.
Rick Allen
>I have often thought that sharpening a bowl gouge with a fingernail jig against an unsuproted sanding belt (belt moving away from the edge) would give a nice convex bevel. Then take the gouge, still in the jig, to the bench grinder to touch up the cutting edge. That would give a convex bevel with a short grinding wheel bevel next to the cutting edge.
>John,
There are two examples in the Grinds Library.
First is Ellsworth's 3/8 detail gouge. I have one with that grind and it is my primary tool to finish bowl bottoms.
Second is further down posted by Rudd F. I also use this grind for inter bowl work.
Both tools are ground (by me anyway) by a combination of jig and freehand. I used the jig to eatablish the the edge and profile, then freehand to remove the concave bevel to a convex shape. The detail gouge is sharpened with a diamond hone. The bigger bowel gouge just with the 120 grit wheel and then a micro back-bevel put on the inverse with a hard arkansas slip to remove the wire edge. I find that the smoother I keep the bevels the smoother these tools cut; especially on the 3/8" detailer which I use like a mini skew.
mm
Where is the Grinds Library?
keith zimmerman, Normal IL
Re: Where is the Grinds Library?
>Look Left
scroll down to "Odd and Ends"
mm
tormek?
JohnKJordan in East TN
>Do you have a Tormek? The gouge jig has a sliding feature to let you add a secondary bevel. I usually use it to make a convex seconary "bevel" to avoid the sharp transition that tends to mark the work. I haven't tried it as such, but I think it should let you do an entire convex grind while keeping the desired tip profile.
Craig Daymon
>How about if you made a jig similar to the Vari-Grind, except with a rotation point instead of the locking nut? Then you could rock the gouge on the wheel as you grind it the way you normally would. This should produce a convex bottom to the gouge like, I think, you are shooting for.
Just an initial starting point of an idea, so don't trash it too fast. I'm sure there is some fine tuning yet to be added.
-Craig
adrien
>Couldn't find a Rudd F picture. There is one by RUSS F, Russ Fairfield.
Doug Thompson near Cleveland
>I posted pictures of Johannes michelsen's grind on WOW about 6 or 8 months ago. If you can't find them send a email and I will send a copy.
I use that grind... well try to use something close... well they look terrible but they work.
>That mudt be the one.
Dennis in Southern Oregon
>John, I think that the following will work if you use a varigrind jig or one of the equivalents: After doing a basic grind, slip a folded wad of paper towel(or other material) into the pivot cup of the jig so it moves the jig closer to the grinding wheel and repeat the grind. If you this repeatedly with thicker wads each time, I believe that you can get the convex grind that you want. Some experimention will be required to get the proper thickness of wad. I have not tried as such, but I often stick a finger behind the pivot after doing the basic grind and repeat the grind to knock off the sharp heel on the gouge. Dennis
