>News flash...playing with a lathe produces a whole bunch of chips and dust!
My shop is in the basement. So is my furnace. My wife has allergies that cause skin breakouts from time to time. I suspect dust from turning exotics may be a contributing factor, although the dermatologist didn't seem to think so. I suspect the dust I produce, and probably carry upstairs, may not help much, though.
So, I want to try to control as much dust as possible at the lathe. I have a DC that I will be connecting in the next couple of months, and would like to connect the system to my lathes (a Jet mini and a Jet 1442). I also have a good shop vac that is very quiet. I am looking for ideas for hoods/boxes/traps that would help collect chips and dust. The attachment gizmo I saw at Rockler doesn't look like it would be very effective. Any ideas, pictures, etc.? Do you trap dust/chips at the lathe, or am I just wasting my time?
>...and very effective solution for a DC hood. It's made from a home type heating/AC system beturn box available in most big box building supply stores.
>What are the dimensions of that thing and what is it called? You know the clerks in those borgs are clueless even when you are buying something for its intended purpose, let alone a redirected application.
Thanks, Jamie. I love your brilliant, and phrugal solutions!
>That might be called a plenum. For whatever reason boxes are often known as plenums.
If it had the duct port already attached it might be called a boot. A supply boot. Most supply boots are turned ninety degrees to the air flow and are either 2 1/4" by 10" or 4 by 12". There is another version that is aligned with the duct and its called an "end boot" I have made great use of boots in my dc system. Easy to get and much cheaper than some of the DC stuff.
Other pieces that might be useful are "take offs". Used to cut a hole in a rectangular supply duct and take off a round duct.
Go to a HVAC supply company and study their catalog. There are many fittings not carried by the borgs that might be useful. They may also ahve four, five and six inch ducts and fittings.
>Joe I have a basement shop also. Mine is a former garage and does not share a heating system with the house. What I have found is that warm air rises. (Duh!) But what that means is I want the shop to be cooler than the house. If I run the heater in the shop and leave the door open, the amount of dust that goes up into the house is significantly higher than when I run the AC and Keep the door closed.
My house keeper commented that adding the AC cut way down on her work. I used to leave the door open and let the AC from the house fall into the shop, but did not really consider that that meant the warm air (and dust) from the shop floated up into the house.
Keep your shop cooler than the house.
When I put in my DC I put it outdoors in a small closet. Keeps the dust and dirt outside along with the noise. It was a great move. It creates a negative pressure on the shop and if anything sucks air down out of the house, preventing dust rising up there.
Also, if you shop is heated and cooled with the same system as the house, you need to use excellent filters and change them frequently.
Walnut dust is an irritant for my skin and lungs. I can tell you that it takes a very small amount to "get me going". The stuff bothering your wife is probably nearly invisible.
An excellent Ambient Air cleaner might be a good thing also, but there is some controversy. One theory is that they keep the very small particles flying long enough to capture them and that might mean you or your wife inhales them before they settle out or get caught.
>Woodcraft has a Dust Hood With Stand (Catalog Number 147113) for $59.99 plus shipping. It's used with your DC unit. Does a good job collecting dust when sanding, but not affective picking up the shavings and can even be in the way, while turning, when moved to close to the lathe. The wood shavings from the lathe can be swept up, but dealing with dust is a problem.
>Here is what I use. I got the hood from Woodcraft for about $22 and had a friend fabricate the bracket. I should have made the bracket at a steeper angle. I also have an airfilter above the headstock. I don't collect shavings and use this mostly for sanding. Seems to work fairly well.
I built a dust filter for my shop similar to the commercial ones from Jet and others that hangs from the ceiling and collects dust from the air in the shop. Mine is an old AC blower I go for free from my friendly AC man. I built a 2' x 2' plywood box to house it. I attach 2 24 X 24 AC filters to sides (which are open)with tape. Turn on the blower and it sucks air through the filters. Picks up lots of dust.
>Joe, Heres my solution- I have the smallest and most quiet DC and it works great. I work out of my second bedroom. Tarped everything off and the DC does the rest. I still always use a mask but it takes care of most of it. The black adapter I believe you can get at Rockler Woodworking for about $22, It is the dust chute for a table saw. I used masonite cutout to adapt it to my headstock. I rewired the DC with an inline switch. I put a magnet on the back of the switch so I can stick it wherever Im working on the lathe. Good luck with your system, hope this helped. r
>As you see, most turners use some sort of commercial or home-made "box" attached to a DC. That 's what I do , too; mine is a fairly cheap commercial plexiglass box that I got from one of the Woodcraft types. You can actually see it sucking up the fine dust, which is the harmful stuff. But, to tell the truth, nothing simple works all that well. My shop is forever covered with dust. So what I also have is one of the hanging dust filters, and after every sanding session, I turn it on and use my air compressor to blow the dust off everything. You can see the dust floating through the air and being collected in the filter. I have a feeling that if we want air that meets OSHA standards, it's a big deal.
I don't bother to even try to collect the larger chips and shavings, but my contraption seems to be very effective on the finer dust that results from power sanding. A few years ago, I turned a four-legged stool over Christmas vacation, and by the end of that project, everything in my basement had a thin coating of dust. That's when I decided to do something about it. So, I installed a run of ductwork from my 1.5 HP single-stage Delta dust collector and attached a 2' length of Loc-Line on the end. The great thing about the Loc-Line is that you can position it and it holds it's shape without any assistance. So, I can position it directly behind a turning on the lathe while sanding and it collects a very high percentage of the fine dust.
>I bought the Rigid 16 gallon vac setup that included a noise muffler.
Much to the annoyance of a "customer service representative" in the orange apron, I insisted that the display sitting on the floor be hooked up so I could hear it. Without the noise muffler installed, it was pretty loud. When the noise muffler was plugged in, noise levels dropped about 30%, with, maybe, a 10% reduction in suction and no apparent loss of motor speed.
I also have a Fein Turbo II intended for dust collection from handheld sanders, etc. With the noise muffler installed on the Ridgid, you would be hard pressed to distinguish the Ridgid from the Fein by noise level alone. Both are orange. Maybe that's the key.
For what it's worth, HD sells the noise muffler for $8 or so, well worth the investment.
I actually intended the Ridgid for garage/ shop floor use, not collecting wood chips and dust. Because it was so quiet, it found its way to my shop instead of the garage. The big, black Craftsman banshee still rules the garage.
>I use a DC hood on my Oneway 2436 which I find to be very effective for dust, not so much for shavings. This may appear to be overkill but the DC I use and the hood mean that there is no reason to wear a dust mask when sanding at the lathe. There are some collateral benefits as well.
The floor of the dust hood provides a stable place to set tools. I will often use 5 or more tools when turning. Having those tools at hand, without fear that they will roll onto the floor is a joy. I also have moffet lights mounted on the dust hood which provides good support for that sort of lighting.
You could make this hood out of wood and cardboard, I would use wood for the back where the DC hose is attached and be as effective for dust collection. I would expect the cardboard to degrade. But it could be easily repaired and you would likely find that the cardboard lasts many months if not years. You wouldn't gain the collateral benefits.
Note that the hood gets in the way of the tailstock. The Oneway hood is hinged is a couple of places to allow access for tool usage as well as the tailstock. The wrap around which gets in the way of the tailstock is also what makes the hood so effective.
>How foolish would it be to hook up to my house central vacuuming system? The vacuum unit is in the basement, where my shop is, too. Also there is an outlet(inlet?) conveniently within a couple of feet of my lathe. I'm hesitant to use my Crafstman shop vac for this; it is louder than a 747 and the filters clog up really fast with fine material and are a pain to clean.
