Recommendation for new drill press
Dennis in Southern Oregon
>I want replace my half-century old Craftsman drill press with a new floor-standing unit. I want a solid unit with good accuracy and am willing to pay a bit more to obtain that. Anyone have a nomination? Dennis
Re: Recommendation for new drill press
Mark Kauder, Phenix City, AL
>Dennis,
I have only seen, and not used them, but the Powermatic 18" with digital speed readout and the 18" Delta are both really nice.
Mark
Chuck Engstrom
>Delta is coming out with a couple of new drill presses oriented to woodworkers, with, for instance, a table that tilts forward as well as sideways (I think -- don't have the article here with me). You might take a look for them.
Best--
Chuck
>I've been extremely happy with my older Delta drill press consequently I would look really hard at the new Delta with tilting table. I did look at the new steel City drill press. It has a locking quill which is nice if you ever use it for routing or milling operations.
Pardon the Rambling........
>I don't have a specific recommendation for a drill press, but I have been thinking about them in general. They seem to be the least developed of the machines. Little more than a bit that goes straight up and down and a table that doesn't. Clearly not designed with woodworkers in mind and maybe not even machinists for that mater. They seem to have been a good idea that suffers from arrested development.
The table should register on the column so you can raise and lower it without loosing the setup. The Idea that the table just floats around it too stupid or too lazy On the part of the manufacturers to even consider. I know that sometimes its important to be "free" to move the table around the column, but it should do both, Index and have a stop you can disengage to allow the table to be offset.
You should be able to easily and accurately tilt the table on both axis.
And there should be some grooves or tracks and or a fence that allow for accurate and easy positioning of the work. The table needs to be bigger than a dime.
Not a bad idea to have a set of bearings in it that would allow the bit to run fast enough to serve as an over arm router. And enough stroke to be useful.
Somehow there is a lack of feed back to the makers. They make what they always made and we buy it because its all we know. Any body that innovates gets accused of adding "frills". Does a frill sound like something a Manly Man would want to own?
Thanks for letting me rant. Think about what you want to do and then buy the biggest a best suited DP you can find. Actually, telling to think about what you want it to do is sort of stupid on my part, like when your mother told you to be careful. (You thought you were). You may know what you want to do now, but you may not know what you want to do a year from now. The basic machine should be versatile enough to accommodate you and should benefit from the thinking of many people. You should not have to invent the excellent drill press, it should offer you features and possibilities you had not even dreamed of.
Jesper, Denmark
Your machines exists......
Jesper, Denmark
>It's called a Bridgeport.
Maybe a bit too much for woodworking, but all the features you describe exist in metalworking machines of various complexity.
Re: Your machines exists......
>As I wrote that I knew I was making a mistake. I had great expectations, but the poor old drill press was just not the place to start. Now where can I get a Bridgeport that will fit in my shop and run off single phase current for less than $299. And it must be indestructible, perfectly accurate, and easy to operate. No, I'm not unreasonable, I'm a consumer.
It does seem that there would have been some evolution in drill presses (and other tools) incorporating the ideas I mentioned. The basic drill press must be a hundred plus year old design. Just seems that somebody would have come out with one that offers more to woodworkers.
Re: Pardon the Rambling........ *LINK*
Peter Hyde
>Well there is this one. The head pivots and moves in and out on dovetail slides. The table is keyed so that it doesn't rotate when being raised or lowered. The table has enough slots to satisfy any need. So I guess this is maybe close to your perfect DP :-)
OWWM
check quill depth
JohnKJordan in East TN
>Make sure you get one with an adequate quill depth. One of my drill presses cannot go deep enough to drill a pen blank in one shot.
Pillar Drill
Tim GC
>Bench mounted but may be worth a look
Google for SCHEPPACH RABT16X
Rick Allen
>Ryobi used to make the WDP 1850 woodworking drill press. That drill press had most of the attributes you mentioned. Why did they discontinue the product? Why didn't Delta make a comparable product?
>Thanks to everyone for the inputs. Dennis
Pete in Holland, MI
>Quill stroke is something that separates the cheaper and more expensive machines. A locking quill would also be nice. Stroke adjustment. Internal light. The lasers that some offer would seem to be more trouble than they're worth. Speeds down to 150 rpm are nice when drilling large holes or using circle cutters. Switching speeds by moving belts is fine with me. A frequency drive or Reeves drive would be overkill. Would rather put my money elsewhere. Be cautious of putting a drill press on a moveable base. Drill presses are very top heavy and typically have small bases. If occasional mortices need to be made, the drill press option is kinda cool. Not as good as a real morticer, but far better than drilling & chiseling.
Hope this helps.
Oh, and, don't get rid of your current machine if you have the room. It's nice to use for a countersinking machine or having 2 set-ups going at once.
