Looking for faceplates
Brian Hahn in SW Wisconsin
>I'm preparing to switch from my Conover lathe to the Robust lathe. Faceplates are still on my to-do list. The Conover faceplate has a lip around the outside (see picture below). That lip is such an outstanding advantage that I'm not willing to give it up.
My question is, does anyone still sell faceplates with a lip around the edge?
The closest thing I've found is a screw center faceplate at Craft Supplies USA. I'd have to remove the screw, plus it is a little expensive for my application. My other options are to buy adapter for my Conover faceplates ($60 each) or to buy standard faceplates and modify them.
Re: Looking for faceplates
Don in Central Illinois
>I hate to act dumb, but what is the advantage to this lip. Also, you should be able to get any faceplate and have a local machinist cut out the center to form a lip.
Advantage of the lip
>The biggest advantage of the lip is that the faceplate only touches at the outer edge, so the wood under the center of the faceplate can be uneven or domed (convex) and the faceplate won't rock on the piece. It makes for a vary solid and trouble-free attachment.
The second advantage is that the screws always raise a little cone of wood as they enter the piece. The lip provides plenty of clearance for that wood so it isn't a problem. (Another way to avoid the problem is to relieve the front of the faceplate around the screw holes, typically with a counter-sink bit.)
It is simple to modify standard faceplates with a wood lathe with standard HSS tools (scrapers). It just takes time and effort.
Ric Taylor
Ric Taylor
>The advantage is the same reason a recess is usually designed into the foot of a bowl or plate.... a slightly uneven surface can be placed against it without rocking.
Ric
Re: Advantage of the lip
>Thanks. I had not thought of those, but it makes sense.
>Brian I don't make a lip on the faceplates that I make but I countersink the screw holes on the bowl side of the faceplate to counteract the fibers being pulled in by the screws. So far it's worked great.
B T Ferraro
>Brian,
While your searching for faceplates similar to the Conover, I thought I ask if you have a source for Conover faceplates. I was supposed to receive an extra with my initial order but it never happened. I do have a face plate with the screw mount attached but that it. I yet to find anyone that has the Conover threaded faceplates.
Sorry for the tangent, but doesn't seem to be much information about
the Conover Lathe. Good luck with your search.
Faceplates, tool rests? Call Bill *LINK*
>Kuhlemeier at the link.
I bought one of his and gave away my others!! [Replaced, of course]
Brian, Bill countersinks all his plates, but if you want lips, you get lips. Just ask.
SeaHorse
Re: Mark, that's a good link...
Allen Neighbors
>to have. Thanks for posting it!!
>Craft Supplies USA has several faceplates with a 1-1/2" - 8 TPI thread.
B T Ferraro
>Thanks Brian.
HarryB in Kulpsville
>Try Bill Noble. He makes face plates from nuts welded to a washer. He seems like a good guy and trys to accomodate his customers. Check his web site at: http://www.wbnoble.com/
Stuart Johnson
>I bought faceplates from Bill plus a vacuum pump. All were very reasonable but I do have a problem with the faceplates. They do not seat well on my Nova 3K. I need to use nylon washers. This is probably true with most if not all made by welding 1-1/4 x 8 nuts to a washer. I also had to use a file to get them to run flat. Sort of like using a sanding board to flatten a segment ring.
I don't know if the proper seating is only an issue with the Nova. I have also run into a problem taping a blank and making a glue block. When threaded on it locks the spindle unless I use a washer. FWIW, I don't see any wobble when using the washers.
Re: Nuts
>When welding nuts to a plate or washer, the interior thread must be relieved with a boring bar for the first 1/4" or so. Bill will do this for you, but you have to ask and there is an extra charge for it. Likewise, if you want the "plate" machined to run dead flat, there is an extra charge for that as well. I use Bill's stuff to make vacuum and jam chucks were I'll be turning the working end of the thing to run true, so I don't much care about whether the face plate is pretty or precise; only that it holds.
mm
That's what I thought they were.
>I had looked at the picture on Bill's site and the faceplates looked like a nut welded to a washer. That isn't substantial enough for my purposes. Besides, I can make those myself.
Re: Alan, That's a Great
>Guy.
Bill takes a lot of pride in his stuff. He's the only machinist recommended by Ellsworth. That's fine for the intro, but I have his face plates and they are first rate. Made from a heavy nut fully welded to a 1/2" steel plate that is then drilled and countersunk from both sides, they come with a 1/2" centering punch and the center hole to match. I've put a feeler guage on these plates, and they seat tight on the spindle shoulder and then run true to .0005". Finer than that I neither need nor am willing to pay for. |;-}}}
mm
l, e
>Sadly missing from last post.
Sorry Allen
