Thanks Everyone *Pic*
Ron in Drums PA
>Thank everyone for all your suggestions.
I may be able to reglue the stone, but gluing up the ebony and hiding the glue line would be a problem. It's easier to start from scratch. I will start to make a new feature ring, only because I'm to stubborn to quit just yet.
This isn't the first one I've done, below you can see one that I've completed. I didn't like the feature ring on this one or the brass "cap" either. So I made a few design changes to the feature ring and changed the shape slightly.
I can save the bottom staves, which is really no big deal. I can cut and glue the parts in a few hours over the course of a day.
In case you are wondering, I used copper between each stave.
Re: Thanks Everyone *Pic*
Wally Dickerman in Arizona
>Copper and brass? I really like that Ron. I'd like to see a pic of the whole piece. I like the idea of featuring the rim in some way. I try to do that on most of my pieces.
Wally
>You are a madman, a glutton for punishment. I tried one piece with an aluminum inlay in it. Can you say "flying saucer". You were taken aback that it failed. I am impressed you even got one off the lathe. Go for it.
How do these howl up over time with all the different materials and the various expansion characteristics?
Steven Antonucci
Method of work question?
steve antonucci
>I think I know, but I'll ask...
I'm assuming that the lower section and upper section are joined together individually first. The feature ring is joined to the lower section, then the upper section is joined to the whole thing?
I wonder if it's viable to turn the whole form by constructing a "one piece staved form", and then parting in a "feature channel" and inlaying the feature ring a piece or so at a time? This would assure that the top and bottom sections were perfectly aligned, but it probably makes it harder to put the feature ring around since the back would have to be curved?
Maybe do it this way, but part the vessel into two (top and bottom) and then turn a feature ring with a rabbet top and bottom? You'd get continuous aligmment, assuming you glued it back together properly...
So how do you make one of these?
Steve
Never accept segmented advice from a guy who burned the only segmented piece he ever made- all five segments...
Bob Way, Canton, MI
>I'm a stoneturner at times, and I really admire what you are working on here. Very unique. I hope your continued efforts work out well for you.
Bob Way
Canton, MI.
Re: Method of work question?
Ron in Drums PA
>Steve
You are on the right track Steve. Think of it as three individual sections (four if you count the bottom plug)
First the bottom is glued up and shaped. Then the feature ring is glued on to the bottom and turned to match the outside and inside dimensions. Next the inside of the top is hollow out then glued on. Then the outside of the top is turned. The last step (before parting it off) is too make one or two passes on the inside to clean up the "joints". This is where the mishap occurred.
Of course you can make a "one piece staved form!" It's probably the easiest way to do segmented turning. Problem is, it wastes allot of wood. But it really is good for small stuff. In the next issue of WoodTurning Design I have a project based on this idea.
I'm guessing you noticed that one stave didn't line up exactly in the picture above. That's another killer with the one that exploded. Everything lined up perfectly.
Barry
I'm reasonably sure this will hold up over time. Everything was taken into consideration from the direction of each piece of wood to the types of glues that are used. I did allot of experimentation with small pieces with all these elements to see what worked and what didn't. I even placed one turning in the freezer, left it in overnight. Then the next day placed it outside on a hot summer day. It stayed together.
Wally
Thanks Wally. I always like the way hand tools looked with brass and wood. I figured it's time to turn them together. Brass sheeting didn't work as well as copper and since they looked good together I opted for that combination
Bob
Thanks Bob, I have a couple more ideas on the back burner.
Dale Cook
>Beautiful piece Ron, and a cool idea. There's a-lot of work in a piece like this but it sure is worth it, very nice!
