Re: Drilling a long, thick, accurate hole...
Chuck Engstrom
>Hi Steve -- I routinely drill 1/2" holes of 12 to 18 inches through end-grain of poplar. Wandering is always a problem, but my best results seem to come from starting with a Bullet drill bit mounted in a stout chuck on a stout lathe with the material turning at a relatively slow speed and modest feed rate for the drill bit. Once I've gone the full length of the Bullet bit, I have a couple of longer ones, just longer brad-point types, that I use to extend it as needed.
I am always able to drill all the way through my stock so I then have the option of mounting the workpiece centered on the hole at each end, which of course centers whatever form I turn thereafter. I use a shop-made brass insert in the hole which allows me to drive the piece with a Steb center.
I do a bunch of work for a fellow who drills holes of 7 feet and more straight through cedar for lampposts and such with almost no wandering. His setup uses a special auger held captive at several points along its length so that it has less tendency to flex and thus let the end wander. Quite a rig but not one you'd want to duplicate for a quick small job. His auger is much like the lamp augers available to turners, at 5/16 or 3/8, but they are pretty flexible and would probably work a lot better if they had the moving supports holding on to them like his setup.
Good luck with it!
Best--
CHuck
