3/4" Jamieson boring bar
Don Evans
>Is the hole in the end (not the 45 deg one) offset from center on anyone else's? Mine is and it makes the bar thicker where the set screw is and I'm wondering is it made that way or is mine just an odd ball?
Don
Re: 3/4" Jamieson boring bar
Dennis Daudelin
>Mine is offset too! And it's brand new so that's the way that Lyle is making them these days!
Dennis
>Mine is off set too, and I just got it a couple of months ago. Pretty sure it was that way when I got it. Don't think it moved while waiting for my to get around to using it. I was trying to figure out if it had to do with moving the cutter below center or with giving a little more metal for the set screw. My brain would have put the set screw on the bottom to help keep the shavings out of it.
I was a little exasperated that the set up had only about four bolts and screws and needs about four different tools to adjust it. I guess that's a personal pet peeve. Also found it hard to tighten the little bolt on the swivel cutter head tight enough to make it stay in place. I guess I was fearful of stripping it. I finally added a lock washer under it and will probably add a longer bolt when I get TUIT.
Dick Hines
Dick Hines
>The hole in the end is off set for a reasion but for the life of me I can't remember what Lyle said the reasion is. I think it had something to do with strenth.
