>SWMBO's daughter is in California. Had friend bring back a Redwood burl sitting in a dish of water as a gift. Spouse sees sprouts as pretty. My gouge fingers itch every time I look at it. Think a little copper sulfate would help it along? I mean if it died, I guess I'd just HAVE to try turning it.....
>I've been in the redwood forests (both coastal redwood and giant sequoia), and I've seen these things in all of the giftshops. I've taken one home from the coastal redwoods, and they will grow for a while before they die, typically because they are not in the right climate.
It's not uncommon to be walking through a redwood forest and see many saplings sprouted from the fallen trunks. There is something magical about a redwood forest.
I'd suggest that you enjoy it for what it is now, and when it dies, you'll have your burl.
And if you plant it directly over, or anywhere near a sewer line, or septic tank, or leach lines, it WILL get in. the previous owner of my home a) put in the sewer line himself - using "shorts" he got off his construction sites b) went with the shallowest slope possible in order to minimize digging so the line isn't very deep c) dug a hole DIRECTLY over the sewer line - and had to have hit the pipe when he did and d) planted a redwood tree in that hole.
That tree is now 75+ feet tall
and
I have my own roto-rooter type machine, which I'm required to use three, four or sometimes a dozen times a year.
Redwood is a beautiful wood. Unfortunately, it's also soft. A fingernail will crush the grain. But when you apply the first coat of oil to it - and the grain "pops" it's a joy to behold.
Plant the burl - and in 10 or 15 years it will reward you with an almost inexhaustable supply of stuff to turn.
>Charlie: Here in the east weeping willow and silver maples are the culprits. My old sewer line was tile of course and I had the frequent clogs. The line was 6". In plastic a 4" sewer line is adequate. A 4" plastic line will fit inside a 6" crock line. I opened up the old line and pushed the new line inside the old one. I got 40' or 50'inside the old one before it got stuck. I measured the distance to where I was stuck and dig up the pipe there. I was able to get the remaining new pipe fed from there. We used ABS pipe and glued all the joints and I have not had a clogged pipe since. I hope this helps.
