Something wrong with my Jet mini lathe?
eliot d
>I have the one that's not variable speed. I notice that if I pull on the spindle ,away from the headstock along the axis of the spindle, that it moves about a quarter of an inch. It springs right back, and I don't have any problems while turning . But is this normal?
Re: Something wrong with my Jet mini lathe?
>Eliot You need to tighten the handwheel. Loosen the set screw and then screw the handwheel in until you don't have any play on the spindle. I tighten them until the spindle is binding slightly and then back of slightly.
Richard Allen
Richard Allen
>Hi Eliot
Is there any reason that the hand wheel might have become loose?
The hand wheel has a set screw to lock it onto the spindle.
1. Loosen the belt so the spindle spins freely.
2. Loosen the set screw on the hand wheel and tighten the hand wheel onto the spindle.
3. The spindle should have some resistance.
4. Back off the hand wheel a little (1/8 a turn) and spin the spindle. Keep adjusting the hand wheel in this way until the spindle spins freely.
5. There shouldn't be any play in the spindle and the spindle should spin freely.
If this adjustment takes more than a minute or two then you are making it to complicated.
handwheel problem
>The Jet handwheel and tailstock handwheel frequently come loose. I install an extra set screw in the lathes I work on at 90 degrees to the other one. This solves this problem.
eliot d
>Thanks guys; I'll do exactly as you say.
